NEW!! pureXbmc V2.1 - New firmware now for CX-919!
Originally posted by Dingelbert View PostInstalled this rom after having problems with the device. Have to say that I am very happy with it. Nice and smooth, no problems playing and streaming with xbmc. Both were a problem in the past.
Thank you!
Originally posted by peety View PostWere you using a ethernet adapter or wifi?
Tried a ethernet adapter once and fried the router port. Have a new adapter that still need to try out. But first I needed a decent working stick.
I like this rom so much I might buy another one for the bedroom.
Live Streaming?
Installed this Rom and V7 Kernel, and I must say that overall I am very pleased. Many of the features that I was looking for are available. The only thing I seem to have issues with is when I try to stream a live feed via Chrome or Dolphin Browser. We use this to stream a live news stream and hockey games, but there seems to be a lag between the video and the sound. Video slows dramatically but the sound continues for the most part, and video doesn't seem to be able to catch up. This is the one thing that did work on the stock rom a bit better. Any suggestions? Is it the wifi not buffering properly? Or do I need to find another browser that is more stable? Anyone have one that is?
Sources available?
Originally posted by walter77 View PostKernel V7 for CX919:
kernel_cx919_1080p_v7_walter77_cpu1608_ddr696_gpu6 00h_vsync.zip
Additional kernels V7 with different ram speeds and voltages:
kernel_cx919_1080p_v7_walter77_vsync_cpu1608_gpu60 0h_ddr400-ddr696.zip
I'm experiencing only some minor issues, as random kernel oops (maybe due to outdated patches) and a broken hidraw, which avoid the mapping of some Mele F10 keys (call, hang up, mute, smart assistant).
I'm willing to try to help with this. Do you have a git repo with the sources/config/patches used in your kernel?
If you don't have a repository, do you mind to share the sources?
With kind regards
Originally posted by eramamma View PostWell after a few days it stopped working altogether. The mouse function was extremely slow, and any video that was played either streaming or from attached USB drive wouldn't play normally. You could hear sound, but the video itself was frozen. So I guess I am looking for a more stable rom.
Sent from my iPhone using TapatalkDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by ps3desb View Post@walter77, this is the best kernel I've tested so far. Congratulations and thank you!
With kind regards
DONATIONS
Originally posted by walter77 View PostIt's almost the radxa source with some minor changes. I can share my source cause i'm on a passive mini pc with windows 7 now.
If we all always have to start from scratch, we will hardly advance. I think everyone will be grateful if you share your knowledge when you have some time.
We are all in the same boat, all trying to push the limits of these devices and make our hobby better.
With kind regards
Originally posted by ps3desb View PostYes, please consider this.. I'm sure the "minor" changes you made are important to make it as good.
With kind regards
Gesendet von meinem iPad mit Tapatalk HDDonations are welcome and will be shared with other devs:
DONATIONS
For my needs, it's solid as a rock: No kernel oops so far and hidraw working properly -> Full functional Mele F10 now!
Anyway, thank you for your efforts.
With kind regards
Originally posted by ps3desb View PostWell, nevermind. Just got it working fine using unmodded radxa sources and default marvin configs.
With kind regards
All the best
Walter77
DONATIONS
Originally posted by walter77 View PostPerfect! So would be nice if you would like to share your kernel here.
Code:[COLOR=#222222][FONT=arial]./marvin config cx919 1080p cpu1608h ddr600 gpu600h[/FONT][/COLOR]
My device is a MK809IV chinese ripoff, MK3188T and AP6210 WiFi. CX919/compatible firmwares works fine and your kernel was the best I've tested so far with it.
With the attached kernel, hidraw mapped my Mele F10 Pro to /dev/hidraw0. (may be different for other setups, check using dmesg). There you can scan every key press, including call, hang up, mute, smart assistant, mouse mode on/off, remote control mode on/off.
As I couldn't yet manage to map these keys using HID Profiles in keylayout (e.g., key usage 0x0c0001 KEYCODE_ENDCALL), as a workaround I've mapped these keys using a shell script. I'm planning to try to code a hidraw wrapper and send signal to keypress event, but it's just a plan for now.
The (quick n' dirty) shell script workaround is the following:
Code:#!/system/bin/sh while true; do keycode=$(hexdump -ve '1/1 "%.2x"' -n 6 '/dev/hidraw0') case "$keycode" in 024903020000) # call -> play/pause input keyevent 85; ;; 024a03020000) # hangup -> stop input keyevent 86 ;; 024803020000) # audio switch -> sound devices manager am start -n com.android.settings/.SoundDevicesManager ;; 024703020000) # remote mode # not mapped for any function yet -> suggestions? ;; 024b03020000) # smart assistant -> open web browser am start -a android.intent.action.VIEW 'http://www.google.com' ;; 024603020000) # mouse mode # not mapped for any function yet -> suggestions? ;; esac done &
If the script works for you, you can save it to /etc/init.d/98mele and make it start at every boot.
Kernel and config generated by marvin follows attached.
With kind regardsLast edited by ps3desb; 13 October 2014, 00:33. Reason: Detected that kernel wasn't patched correctly. Will upload another version, if needed.
There are currently 1460 users online. 0 members and 1460 guests.
