Thanks for your work! I just flashed with
NEW!! pureXbmc V2.1 - New firmware now for CX-919!
Hi walter77,
Originally posted by walter77 View Post
Originally posted by ps3desb View PostSure! But as I told, it's just pure Radxa compiled with Marvin. The config was the following:
Code:[COLOR=#222222][FONT=arial]./marvin config cx919 1080p cpu1608h ddr600 gpu600h[/FONT][/COLOR]
My device is a MK809IV chinese ripoff, MK3188T and AP6210 WiFi. CX919/compatible firmwares works fine and your kernel was the best I've tested so far with it.
With the attached kernel, hidraw mapped my Mele F10 Pro to /dev/hidraw0. (may be different for other setups, check using dmesg). There you can scan every key press, including call, hang up, mute, smart assistant, mouse mode on/off, remote control mode on/off.
As I couldn't yet manage to map these keys using HID Profiles in keylayout (e.g., key usage 0x0c0001 KEYCODE_ENDCALL), as a workaround I've mapped these keys using a shell script. I'm planning to try to code a hidraw wrapper and send signal to keypress event, but it's just a plan for now.
The (quick n' dirty) shell script workaround is the following:
Code:#!/system/bin/sh while true; do keycode=$(hexdump -ve '1/1 "%.2x"' -n 6 '/dev/hidraw0') case "$keycode" in 024903020000) # call -> play/pause input keyevent 85; ;; 024a03020000) # hangup -> stop input keyevent 86 ;; 024803020000) # audio switch -> sound devices manager am start -n com.android.settings/.SoundDevicesManager ;; 024703020000) # remote mode # not mapped for any function yet -> suggestions? ;; 024b03020000) # smart assistant -> open web browser am start -a android.intent.action.VIEW 'http://www.google.com' ;; 024603020000) # mouse mode # not mapped for any function yet -> suggestions? ;; esac done &
If the script works for you, you can save it to /etc/init.d/98mele and make it start at every boot.
Kernel and config generated by marvin follows attached.
With kind regards
How to choose the 7 files for flashing this rom
Hi guys, i just got a CX-919, i used to have a rikomagic mk802III wich i used a couple of diffrent roms on, but i am having trouble installing this one on my new Cx.... can some one explain the flashing process with the rkbatchtool v. 1.37? and wich of the files in the downloaded folder corresponds to the files the tool requests ? coz as far as i can tell it wants the loader file twice... and that confuses me a bit...
Donations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
CEC support
@walter77
I bought what I thought was a CX-919 (looks like it), however after installing this ROM the wifi stopped working. I later noticed that the original ROM was this one:
T010_8723bs_4.4_1080p_20140918.img
(this link: http://chinagadgetreviews.blogspot.p...rmware_13.html
or this link:
http://www.mediafire.com/download/lv.../MK809IV-2.rar)
and I presume I have 8723 wifi chip.
I would like to know if:
- is there any way to adapt your ROM to support this wifi chip?
- is there any way to patch my ROM kernel so that it supports CEC?
Thanks in advance!
or this link:
Thanks in advance!
walter77Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by walter77 View PostSorry, can't help you with that. Try to find a good working Kernel and install it on top of pureX KitKat v1.1 rom.
walter77
So you're saying that I should install pureX_KitKat_V1-1_cx921a, and on top of it I should install only a new working kernel that supports the wifi 8723bs (like http://www.freak-tab.de/d33/kernel_K...TL8723BS.zip)?
Seams easy enough! I will try it tomorrow!
(if you could just confirm your confidence degree on this procedure, I would appreciate)Last edited by SolGarlic; 04 January 2015, 03:28.
Originally posted by SolGarlic View PostI had the idea from your first post that the CEC support was in the kernel!
Walter77Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by SolGarlic View PostWorked flawlessly! I used the kernel for HD stick, and had no problem with WIFI, however, apparently there is no CEC support. Should it work?
I never tried it or searched for it.
Walter77
Gesendet von iPhone mit TapatalkDonations are welcome and will be shared with other devs:
DONATIONS
I have one of these - http://www.geekbuying.com/item/Trons...ck-316975.html ...................... I am not having much luck here. I tried your other KitKat one (http://www.freaktab.com/showthread.p...921-and-CX-919)................... and couldn't get wifi at all ..... LAN is available but I only use wifi. So I came over and tried this one. The main issue is 1- I start SPMC and it crashes and reboots my stick within roughly 15 seconds .... happens everytime. 2- Skype almost works but again crashed and reboots the stick ..... I had given up on the stick ages ago and it was just hanging in the back of my smart tv but came in for a wee look here and got excited thinking I might actually get some use out of it. Is there something I am doing wrong as I read a post of yours saying it works "perfectly" on the 919 ............ ps ..... awesome support you have offered ..... not many developers bust a ball as much as you have.
There are currently 2371 users online. 1 members and 2370 guests.
