This is a KitKat ROM.
This ROM is:
Rooted
Debloated of all of the Walmart/Sam's Club apps
Init.d/Busybox support added
Google Play Store fixes
Auto Install of apps in the external SD "autoinstall" folder.
Reboot App by Petrus
New Boot Animation
Since this is from a ROM dump, I've unpacked and repacked the boot.img and recovery.img files to make them the correct size. I've kept the stock parameter file, so you will have the same user app space, until I can figure out how to change it...there's a line missing in this parameter file...so I'm afraid to mess with it...I don't know how a change will react on your tablet. I believe that apps are being installed on the internal SD...so there's no need for other parameter files.
Just run the flash tool and plug in your tablet using the USB cable that came with it. Make sure USB debugging is turned off. The flash tool should see your tablet in Mass Storage Mode. Click reboot to flash and it will change to flash mode.
IMPORTANT: Uncheck the loader.bin at the top, it's checked by default. The reason for this is, we are going back with the same firmware. I don't know which loader.bin is currently on your tablet...so the one included in the kit will brick your tablet, if it isn't the same. It's ok to use the same loader.bin with the same firmware...so don't worry.
Erase IDB, then flash the ROM.
It will first boot to recovery and format everything. Later, if you want to flash CWM or TWRP recovery, you can just flash it instead of the stock recovery from the flash tool.
Here's the link:
Download v1.0
Here is a newer version based on an OEM ROM dump provided by Freaktab user steve&b.
This new version contains the same features listed above, with auto installation of TWRP Recovery (by Abdul_pt) on first boot. When you flash the ROM, you will see the stock recovery format the partitions. Wait a couple of minutes before rebooting on the first boot to system. Then when you reboot to recovery, you will have TWRP.
Download v1.1
Download v1.2 (based on a more recent ROM dump from FT member TRR.
Download v1.3 (based on an even more recent ROM dump from AndroidFanatic)
Download v1.3.2 (based on the same firmware as 1.3 with a script provided by AndroidFanatic to help with the installation process. See post #182 for instructions on how to use it. This script will help install the drivers and get your tablet into flash mode)
Enjoy!!!!!!
Donations Welcomed...please tip the developers.
.gif)
