Hisense Sero 8 RileyROM 1.0
I uploaded v1.2 of this ROM based on a new ROM dump furnished by Freaktab user TRR.
I've experimented with some test parameter files you can try. Just browse the parameter line in the flash tool to one of the parameter#.txt options and see if you get a change in user app space. I'm not sure they will work, because this parameter format is different.
See post #1 for the link.Randy
I have flashed v1.1 and v1.2 several times now and I continue to be stuck on the rotating animation. The tablet will NOT boot anymore.
Starting with the first flash v1.1. I erased IDB then flashed all files including the loader (not userdata or backup).
Did this a few more times.
Then I flashed v1.2 the same way, erased IDB, flashed all files except userdata and backup).
Still bootlooping... final flash I used v1.2 but used all STOCK ROM files except for boot and system (also Riley loader was flashed again). This is the minimum for getting ROOT.
What about my original loader? That has been flashed over so I cannot reflash that file to stock. Why am I stuck at the rotating animation after sereval attempts and cannot get my tablet to boot anymore.
Oddly, my computer still picks up the tablet as a Portable Device, probably reading the SD Card even while it is still looping.
What do I do?
Randy
All Linux though, huh? No Windows-based tools?
Guess I could dust off an old PC and put Linux on it to play if there's no other way...
I'm running a Windows 8.0 laptop with an Ubuntu Virtualbox. It works great...does both at the same time.
Most of the ROM work is done in Ubuntu, but I need Windows for most other things.Randy
RileyROM differences?
Randy,
Could you give a brief description of differences from 1.0 to 1.2? Do all three have bloat removed? If so, the same bloat?
Does the 1.2 version have TWRP?
If I wanted to update from 1.1 to 1.2 what would I gain?
If I didn't want TWRP should I use the recovery.img and parameter from 1.0 when flashing 1.1 to 1.2?
Thanks for all your work and help.
The difference is v1.2 is based on a newer ROM dump. That's it. I did not change anything else...except the boot animation. All of the RileyROM features mentioned in post #1 are there.Randy
As far as I know, v1.2 is the latest update...unless there has been an update since we made this ROM dump. If you install v1.2, you shouldn't get an OTA update (unless there is a newer one available).
Since I don't have a link to firmware updates for this device, It comes in handy when someone provides me with an updated dump. That's why I haven't totally disabled the OTA updates...but I can in the next ROM.Randy
I just got this tablet today, got all the Google updates and Sero updates. While messing with it i switched from Davlik to ART.
Now I am noticing 2 weird problems:
1. the YouTube app is not working. Always a "Connection to server lost. Touch to retry" error.
2. in Chrome there are some flashing black areas on some webpages. Even more so on Google.com
Has anyone else experienced these problems?
I would steer clear of ART right now. It seems to be the root of problems. App comparability is one thing. For instance, Xposed Framework doesn't work with ART.
Sent from my P1Randy
Originally posted by rrileypm View PostI would steer clear of ART right now. It seems to be the root of problems. App comparability is one thing. For instance, Xposed Framework doesn't work with ART.
Sent from my P1
Quick question... which chip manufacturer/tablet maker is giving you the most support? I ask this because I want a China tablet but custom ROMs are a must for my choice. I am trying gauge which one will have the most longevity after release. Right now i am leaning towards the Intel tabs but the A80s seems more capable
There are currently 1356 users online. 1 members and 1355 guests.
