Edit: "found erase IDB" Also, I think I am in flash mode, but the flash tool still does not see the tablet.
Hisense Sero 8 RileyROM 1.0
driver installed
Originally posted by Jefedfur View Post
Edit: "found erase IDB" Also, I think I am in flash mode, but the flash tool still does not see the tablet.Last edited by xrko; 02 October 2014, 22:31.
(DEPRECATED, USE v2 INSTEAD)
Extract this zip(https://drive.google.com/file/d/0B5mb3cMYjZWicmlTRGVhWXppSXc/view?usp=sharing) to the root of the RileyRom Folder and run "InstallDriversAndRebootFlashmodeHelper.cmd" and follow the prompts to help get the drivers installed and reboot your tablet in flash mode. Remember to enable USB debugging for it to be able to reboot into flash mode for you. After that it would open the flash tool for you, where you can "Erase IDB" and flash the ROM. Hope this helps you guys!"I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by AndroidFanatic View PostExtract this zip(https://drive.google.com/file/d/0B5mb3cMYjZWicmlTRGVhWXppSXc/view?usp=sharing) to the root of the RileyRom Folder and run "InstallDriversAndRebootFlashmodeHelper.cmd" and follow the prompts to help get the drivers installed and reboot your tablet in flash mode. Remember to enable USB debugging for it to be able to reboot into flash mode for you. After that it would open the flash tool for you, where you can "Erase IDB" and flash the ROM. Hope this helps you guys!
edit: device mgr info on driver: class of Rockusb devices/rock usb device. Driver provider Fuzhou Rockchip 8/5/2013Last edited by xrko; 03 October 2014, 23:26.
Originally posted by xrko View PostAndroidFanatic, no luck. If I select 1, it says "the system cannot find the path specified." Hitting enter puts you back to the 1 or 2 selection. Hitting 2, says "error: "device not found" and then it closes. I enabled USB debugging and tried with the tablet running and with it shut down. Sorry for the trouble and thanks for the help."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by AndroidFanatic View PostYou were supposed to extract to the same folder as RileyRom and then you were supposed to select option 1 to let it install drivers. After that you were supposed to select option 2 and you were supposed to keep tablet on after enabling USB debugging to let it reboot device in flash mode. After that you would hit enter to let it launch the flash tool. Hope that solves your problem! Make sure you have your device plugged in and run this script as administrator if your still having troubles!
Originally posted by xrko View PostI am extracted to RileyRom. I have tried every combination and still get the same results. After selecting 2, I get: Now we are going to open flash tool for you. You may exit after it opens. "Rom_flash_tool_137.exe" is not recognized as an internal or external command, operable program or batch file. Press any key to continue-- then it closes. Thanks"I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by xrko View PostThe .exe looks fine. Should the Rom_flash_tool_137.exe be in the RileyRom folder?"I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by AndroidFanatic View PostYes that exe should be in that folder. You only extracted the contents of that zip not put it in it's own folder right?
Originally posted by xrko View PostI extracted the file to RileyRom which is a folder in the 1.3 download. The .exe is in the 1.3 download and not in RileyRom."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by xrko View PostI'll start over."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by AndroidFanatic View PostYeah that would be a good idea, good luck! Hope it works for you this time!I will get it eventually.
Originally posted by xrko View PostStarted over and flash tool opens, but does not recognize the device. I did this with usb debugging checked and tried to reinstall the drivers with debugging unchecked. no luck.I will get it eventually.
Originally posted by AndroidFanatic View PostPost back if there's still problems with the drivers and post back if you figured it out which may help the people who only read these threads.
There are currently 2052 users online. 0 members and 2052 guests.
