[EDIT-SOLVED]: Found the solution. Seems there was a misunderstanding. Thank you to absolutely anyone that would have offered any help! Riley I look forward to the progression of your rom and if I may help, at all, please contact me.
Hisense Sero 8 RileyROM 1.0
Originally posted by Dostov View Post
[EDIT-SOLVED]: Found the solution. Seems there was a misunderstanding. Thank you to absolutely anyone that would have offered any help! Riley I look forward to the progression of your rom and if I may help, at all, please contact me.Last edited by Dostov; 14 November 2014, 16:19.
Thanks for the report.
It's hard for me sometimes to provide specific instructions....because I can't possibly own every device I've made a ROM for. External buttons and key combinations are different between manufacturers. I can point people in the right direction to help them find a solution....but it's the users with exact experience with the device that provide the most help.
I don't have access to firmware updates for Hisense tablets...so if you need an update...please send me a link to the most recent ROM dump.Randy
When the time comes, I will see to providing you with a dump, Riley. Your instructions turned out to be fine, lol. Just did not know I had to do the manual flash boot while the tablet was connected.
STUPID QUESTION ALERT!
In trying to root my Sero 8, the built in memory is full and won't let me do anything (says 13.1gb with a max of 12). I've tried deleting apps and data but can't get the memory usage down enough to be able to even try rooting it (it won't go into recover mode as well). Any suggestions?
Flashing the custom ROM may solve the problem...but that error might be due to a hardware problem with the NAND chip. No way of knowing until you attempt to flash. Just follow the directions in the First Time User's Guide carefully.Randy
Originally posted by rrileypm View Post........
Thanks in advance
If you update you will loose root...but if you dump the updated version either me or AndroidFanatic can make a new ROM. He may already have it on his tablet...he's kind of taken over development of this tablet for me...learning the ropes.Randy
Updated rom dump.
I am going to try to get you the latest rom dump as i have recieved that notification as well. Haven't done this before so bare with me. I am running your rom. I know there is another dev building for this device too but i like options so hopefully you can update this rom for is. And thank you again for a great rom.
I already made a ROM based on the latest update!
Originally posted by rrileypm View PostIf you update you will loose root...but if you dump the updated version either me or AndroidFanatic can make a new ROM. He may already have it on his tablet...he's kind of taken over development of this tablet for me...learning the ropes.
If you flash the ROM located at this thread -> Link"I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
No need, I've already made one and uploaded it!
Originally posted by glockman4519 View PostI am going to try to get you the latest rom dump as i have recieved that notification as well. Haven't done this before so bare with me. I am running your rom. I know there is another dev building for this device too but i like options so hopefully you can update this rom for is. And thank you again for a great rom."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Can't get into flash mode
I seem to be having a little issue... I downloaded a different file that had the same flashing tool that was supposed to install TWRP. I installed the drivers, the flashing app detected it, said it flashed, it rebooted and booted back into Android as expected. I then held volume up and power to reboot to recover and was greeted with the standard looking Android Recover console... not TWRP.. Now I can't get the flash tool to detect the tablet.. I tried doing a factory reset.. My guess is I'm going to have to manually push via ADB. I've double checked to make sure that USB debugging is off - and it's definitely off... my PC recognizes the tablet every time I connect it but the flasher won't even though it detected it fine the first time I tried to flash.
I'm just not 100% sure where to go from here... the tablet still works fine but I wanted it to be rooted >.<
If there's a reset button (hole on the back of the tablet), press it with a paper clip.
Connect the tablet via USB with the flash tool launched.
Try a combination of external keys...volume+ or -, esc/back key...etc and power. There is a way to get your tablet into flash mode manually this way.
When the flash tool sees the tablet, flash as before.Randy
Originally posted by rrileypm View PostIf there's a reset button (hole on the back of the tablet), press it with a paper clip.
EDIT: got it to go into flash mode
There are currently 2945 users online. 0 members and 2945 guests.
