My build number: E2281E0915B1V20
Hisense Sero 8 RileyROM 1.0
Great. If you can provide me a dump of that new version...I'll make a new ROM.Randy
Hisense Sero 8 Rom Dump E2281E0915B1V20
Originally posted by rrileypm View PostGreat. If you can provide me a dump of that new version...I'll make a new ROM."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Thanks for the link!!!!!
I will get to work on a new ROM.Randy
1.) Did you install the rockchip device drivers.
2.) Use the flash tool that came with RileyRom
3.) Booted your tablet in flash mode (Power+Volume Up and flashing IDB before it finishes booting recovery).
If none of the above troubleshooters helped you please post back what still isn't working and hopefully someone here will try to help you further! Good luck and hope I helped!"I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by AndroidFanatic View Post1.) Did you install the rockchip device drivers.
Originally posted by xrko View PostI am trying to install the drivers and I used the flash tool and the BK batch tool-as in the original post. Thanks."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
I have a silly question.
I'm trying to figure out the parameter file for this tablet. Something doesn't jive.
Running the stock ROM, how much userdata space is available to install apps?
I know there is 16gb total NAND.
The stock parameter shows zero app space. Does that mean that all apps are stored in the internal SD?Randy
When I tested the ROM dump I made, the parameter file was like the stock one and the storage page in settings shows there's space for apps. If there's a problem with it please comment below. Wish you luck!
Edit: In fact I'm still flashed with this ROM I dumped and it's been working like the stock one should. In other words the same as stock amount of space. Hope that answered your question (just try to make the ROM using the stock parameter file if possible, it really increases chances of working on peoples device when flashing it)."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
How much space is available for apps on the stock ROM? I need to know if I need to make different parameters for a variety of userdata partitions. If userdata is combined with the internal SD...I don't have to worry about it. I've already made the files...but they could brick the tablet if you flash one and the added space isn't necessary.Randy
v1.3 is now available in post #1 based on the firmware dump provided above by AndroidFanatic.
Thanks, buddy for sharing.
BTW, if you need those extra parameter files, I can add them later.
Also, if anyone wants to add multi-user capability, I've modified the framework.jar file. It is untested, so if you want to try it, PM me.
I hesitate to post it for everyone until it is tested. The reason is that in technical terms...the apk/jar files are odexed in this firmware. I had to deodex the framework.jar file in order to modify it. Therefore, since it isn't proven to work...I need someone to confirm that it does work on your tablet.
it involves replacing the framework.jar and framework.odex files in the system/framework folder with a modified framework.jar.Randy
Your welcome for the help I was able to provide, I hope your 1.3 ROM is more successful at booting than the previous one."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
Originally posted by rrileypm View Postv1.3 is now available in post #1 based on the firmware dump provided above by AndroidFanatic.
it involves replacing the framework.jar and framework.odex files in the system/framework folder with a modified framework.jar."I am a fan of android and other tech stuff like windows and linux on the desktop! I will contribute what I can to the FreakTab community, but only, what I'm willing to" -AndroidFanatic
There are currently 4883 users online. 0 members and 4883 guests.
