Hisense Sero 8 RileyROM 1.0
No ADB access?
I do have an annoying oddity with this Sero 8, and it's been like that since I opened the box (both with the factory ROM and still with the rooted RileyROM):
I can't get ADB 1.0.31 (Windows 7 x64) to ever recognize that the tablet is attached. I'm quite experienced with using ADB on many other brands of tablets and this is the first one that I can't get to talk to me this way. I also have a copy of ADB 1.0.26 in another folder (for older tablets) and the funny thing is that 1.0.26 sees the Sero 8 tablet (when I run 'ADB devices') and shows it's ID number but lists it as offline. That's to be expected since this is running KitKat and requires 1.0.31 to do the security stuff.
But when I try to access this Sero 8 with ADB 1.0.31, the tablet isn't listed when I run 'ADB devices' and it never displays the security pop-up on the tablet screen.
I've got Google's latest ADB driver installed for it and obviously have ADB turned on under developer options, since I can see it with 1.0.26.
Is anyone else with a Sero 8 able to access it with ADB 1.0.31 via USB?
Originally posted by rrileypm View PostYou must keep system.img and boot.img or root won't work. The kernel is the same. I did not modify it.
Originally posted by Jefedfur View PostYou just left the parameter files for different sized storage in the second rom. Its covered in the q&a. The default for the flasher to use is only 3gb in the newer rom.
So essentially, I took my factory ROM dump files (backup.img, boot.img, kernel.img, misc.img, recovery.img, system.img, and parameter) and replaced boot.img and system.img with the files from RileyROM 1.1. Then I flashed it back to the tablet.
I read through this whole thread before doing anything and was thereby able to avoid some of the problems others have run into. Thanks!
If someone can provide me a ROM dump of any newer firmware, I would be happy to provide updates. I don't have a source for downloading Hisense firmware.Randy
Re: Hisense Sero 8 RileyROM 1.0
Originally posted by rrileypm View PostIf someone can provide me a ROM dump of any newer firmware, I would be happy to provide updates. I don't have a source for downloading Hisense firmware.
Ill also start messing with adb and see what I can help with.
Originally posted by TRR View PostIf that was addressed to me, I used my factor parameter file (which was the same as the one from the first RileyRom).
You can simply rename the parameter file, or you can click the browse button on the parameter line of the flash tool and select the parameter with the desired file size.
Keep in mind that you are taking the increased user app space from the internal SD space. You are limited to the total available NAND memory capacity. The system takes up roughly 1gb. Your app data partition is added to that. What is left over is your internal SD size.
I don't know how much total NAND is installed, but I've made partition files up to 12gb. If, for instance, there is only 8gb of total NAND, I would only recommend 4 or 6gb user app space.Randy
Originally posted by Jefedfur View PostIll also start messing with adb and see what I can help with.
As I said earlier, I can see the tablet using ADB 1.0.26 but it's listed as 'offline' since 1.0.26 doesn't have support for the KitKat ADB security prompt.
So, now that I have root, I went in and edited the /system/build.prop file and changed
Code:ro.adb.secure=1
Code:ro.adb.secure=0
ADB 1.0.31 still won't touch it.
Another interesting quirk
Here's another interesting quirk:
I thought I might give the 'ART' runtime a try instead of 'Davik'. Supposedly, it makes things run a bit faster. However, with that option selected in Developer Options, everytime I boot the tablet it takes a few minutes while it's "optimizing the applications".
Switching back to Dalvik runtime stops that behavior.
No biggie - just odd.
It isn't odd. That happens on most KK tablets running ART. All of your apps must be ART compatible, or the tablet will continue to do this on every boot. Sometimes you will find that some apps are missing after this process.
Google has a long way to go with full implementation of ART.Randy
Originally posted by rrileypm View PostIt isn't odd. That happens on most KK tablets running ART. All of your apps must be ART compatible, or the tablet will continue to do this on every boot. Sometimes you will find that some apps are missing after this process.
I'll just stick with Dalvik then.
kernel version
Originally posted by TRR View PostIt may be that the update that auto-installed yesterday on this brand-new tablet changed the kernel.img from the set you had.
The Kernel version on mine (using the kernel.img from RileyROM 1.1) is
3.0.36+
Thanks, I will get to work on it.Randy
There are currently 2461 users online. 0 members and 2461 guests.
