Tapatalked
TWRP 2.7.1.0 Custom Recovery - Compatible with R89
Originally posted by Smokez View PostJust checked uboot is indeed 4mb but resource img is 16mb on my systemMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Possibly, won't hurt to try but you might be better off waiting untill abduls fixed the partitions, not that you could do anymore damage.
What you really need is a flashable zip of the stock ROM, you could stick that on an sdcard or usb stick, mount it in TWRP and flash it...
I'm am in the process of learning how to do this, have managed to make an update.zip that's flashable in TWRP from my Stock ROM dump, it only contains the boot.img and system.img but from what I've read that's all you need, you are welcome to try it, if you want I'll upload for you, again I have no idea if it will work, this is where I need Bob to chime in @Finless
Originally posted by Smokez View PostPossibly, won't hurt to try but you might be better off waiting untill abduls fixed the partitions, not that you could do anymore damage.
I'm am in the process of learning how to do this, have managed to make an update.zip that's flashable in TWRP from my Stock ROM dump, it only contains the boot.img and system.img but from what I've read that's all you need, you are welcome to try it, if you want I'll upload for you, again I have no idea if it will work, this is where I need Bob to chime in @FinlessMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Re: TWRP 2.7.1.0 Custom Recovery - Compatible with R89
Originally posted by clarkss12 View PostI have been at a standstill, waiting for UPS to deliver my card reader. Long story, but could not find my reader, so had to order one. When I get that reader then I can use my micro SD card to play around with and maybe this this box up and running agin.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Smokez View PostFor your laptop/PC I'm guessing, do you have a usb thumb drive?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I even tried to mount the thumb drive with your TWRP, but that was a no go also.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI even tried to mount the thumb drive with your TWRP, but that was a no go also.
EDIT : have just tried the above and can confirm I cannot for some reason mount a usb drive . Hmmmm - without a way of transferring the update.zip to an external SD you won't be able to do it, do you have a phone with removable SD?! Lol
Originally posted by Smokez View Postheres a link to the update.zip which i have no idea whatsoever if it will work, if not then i am fresh out of ideas and you will need to wait until someone can make a proper flashable zip from the stock rom that oman posted.
https://www.dropbox.com/s/hdxbuck6hu...pdate.zip?dl=0MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostDownloading your zip file now. Finally received my card reader. Formatted my micro sd card with fat32, installed updated twrp. Waiting for your zip to complete downloading, and will give it a shot.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Smokez View PostHmmm... Is your external SD mounted? Can you browse external SD in the twrp file browser under advanced tab? Silly question but the SD Card is inserted directly into the R89s micro SD slot right and not via the card reader?
I also see update_R89_107K4106.img.
but I don't see your zip file I loaded onto it. I am going to remove the sd card and verify what is on the sd card, perhaps I did not add the correct files.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3596 users online. 9 members and 3587 guests.
