TWRP 2.7.1.0 Custom Recovery - Compatible with R89
Re: TWRP 2.7.1.0 Custom Recovery - Compatible with R89
Originally posted by clarkss12 View PostThis is where I am now, In file manager under exter_sd I can see the TWRP_Beelink_R89.img, which is Oman's img file he uploaded.
I also see update_R89_107K4106.img.
but I don't see your zip file I loaded onto it. I am going to remove the sd card and verify what is on the sd card, perhaps I did not add the correct files.
Originally posted by Smokez View PostHmmm... Is your external SD mounted? Can you browse external SD in the twrp file browser under advanced tab? Silly question but the SD Card is inserted directly into the R89s micro SD slot right and not via the card reader?
Finally got your zip file to flash, but using twrp reboot, it still comes up to the twrp menu. When I pull th e power and restart the box with the start button on the box. I come back to the no signal. I think you may be correct, Finless may have to save me. Or Oman if he will create a zip file.
thanks for the help. Unless you have some more ideas?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Smokez View PostYeah, you can flash it via twrp then reboot recovery, and try the update.zip, or even the 107k4 img although not sure if it Will workMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I think there's an obvious reason for that I will investigate for you in the morning but my suspicions are that indeed you will need someone to compile a flasgable zip from the stock ROM. I am still in the process of learning these, probably basic things, but gotta start somewhere right! Hope to help find you a solution
Originally posted by Smokez View PostI think there's an obvious reason for that I will investigate for you in the morning but my suspicions are that indeed you will need someone to compile a flasgable zip from the stock ROM. I am still in the process of learning these, probably basic things, but gotta start somewhere right! Hope to help find you a solutionMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Smokez View Post1. The twrp_beelink_R89.img is abduls twrp file linked here in first post, you can go ahead and attempt to flash that via install and selecting ext_storage then the file.
2. I'm not sure where you got the 107k4 img through Oman I guess but I'm not sure you'll be able to flash that via twrp
2. NO, I don't think so, because it's an all in one image and not the seperate parts (kernel, system ...).
If 1. => yes, than use RKAndroidTools to extract the all in one Image (I it can handle it, it not I can show you another tool)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by roolmapool View PostSorry to ask... but any progress on TRWP on RK3288 devices?
Hard to not have a recovery to backup device...
Please see attached for modified TWRP for RK3288 devices.
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Still doesn't pick up all the partitions, hope someone will fix it soon.
Originally posted by mo123 View PostPlease see attached for modified TWRP for RK3288 devices.
There are currently 2747 users online. 3 members and 2744 guests.
