TWRP doesn't work correctly on RK3288, doesn't see all the partitions.
TWRP 2.7.1.0 Custom Recovery - Compatible with R89
TWRP 2.8.4.0 for RK3288
There is a new TWRP version from firmware guru "Oma" available at the Arctablet News Board:
[RK3288 ROM] TWRP/CWM Flash-Tool custom root firmware (2015/01/17) TWRP 2.8.4.0
As you can read, it is tested and installation confirmed (CWM, TWRP 1920x1080) on a Tronsmart R28. So it should run on Beelink/Ubox R89 also.
Originally posted by uli-hh View PostThere is a new TWRP version from firmware guru "Oma" available at the Arctablet News Board:
Has someone managed to install CWM recovery on Beelink R89? TWRP is working, but it has bug. I can not mount USB HDD and save backup on it. Also, otg port is not working. You have to stick air mouse -mini keyboard on ordinary USB port to work. When i tried to flash CWM, i got message that install suceeded, but the i can not boot into CWM recovery. I have tried via Wasser-s reboot menu, and with Pietrus Reboot apk. In both cases, box restarts himself and i get nothing on my tv. Box is not booting android or recovery. Then i have to plug it out and again switch it on to boot Wasser rom. Is there a way to boot into CWM recovery?
Originally posted by gsavicic View PostHas someone managed to install CWM recovery on Beelink R89? TWRP is working, but it has bug. I can not mount USB HDD and save backup on it. Also, otg port is not working.
not working
I tried installing TWRP since you confirmed it is working on a R89. I have an app installed which boots into recovery. The default recovery before was working (but a little off-screen).
I have tried flashing TWRP in two different resolutions and CWM. All I get is a blank screen
Any ideas?
Cheers,
Ropo
Any ideas?
Cheers,
Ropo
No idea why it would work for you, but I know for sure it's working. Did you read instructions well?
Try this - https://yadi.sk/d/zbW-smiJe6XHV : it's my repack for our TV box, I removed unneeded files, made it more obvious and deflated with 7zip SFX. VirusTotal's stats for certain individuals.
Installation process:
1. Make you have USB debugging enabled before continue
2. Download archive and unpack wherever you see fit
3. Get into RK3288_TWRP_1080p folder, launch AndroidTool.exe, permit Administration rights; you should see "Found One ADB Device" status
4. You have nothing to do with location, just press Switch button, status should change to "Found One LOADER Device"
5. Press "Run", process will finish fast and TV box will reboot
6. After reboot go to recovery with any tool you like (Wasser has "Reboot to recovery" option in his firmware, Finless ROM has app called Reboot, it doesn't really matter what you would use)
7. TWRP should load for your satisfaction
You can see pictures here - http://4pda.ru/forum/index.php?showt...#entry37377946
Originally posted by ropo View PostNo, same result with your latest package. It flashes, because my stock recovery is gone. Then when I boot to recovery either by app or using a toothpick it hangs
I have first tried with stock firmware version 110k. Then, after Oma gave the great advice in the arctablet forum to also flash the misc.img partition all my apps were gone. Thanks, Oma.
So I took the chance to upgrade to 111k. Same result here.
I notice a difference in the bootloaders RK3288Loader_uboot_V2.15.02_off vs RK3288Loader_uboot_V2.15.02. Do I need to update the bootloader?
Originally posted by ropo View PostI have first tried with stock firmware version 110k. Then, after Oma gave the great advice in the arctablet forum to also flash the misc.img partition all my apps were gone. Thanks, Oma.
And about firmwares, seriosly, since you've already lost your apps, flash latest Wasser: it has no known disadvantages over stock 111k and this recovery works fine with it.
I flashed wasser now. First impressions: Does not fit on screen. large fonts or DPI?
Then I try to install TWRP -> "No Found any devices"
After flashing, when rebooting Windows installed drives a recognized a "Nexus 10". Now It shows two folders under "Nexus 10", but I cannot use AndroidTool. Tried re-installing drivers and setting checkbox "connect to PC"
Help!
I have enabled debug mode. Removed the Nexus from the device manager. Now it is showing MTP USB Device. I switch it on with the toothpick in AV and I see a device in loading mode. Now I flash TWRP. It reboots and "Nexus 10" is back in "Portable Devices". I want my adb mode back! I boot wasser, then into recovery. TWRP is working. Some pixels cut off on top of screen but working. Yeah! Creating a backup. 1GB. Should have bought a faster sd card. I swithed off the checkbox in "Connect to PC". Still no adb mode. How do I get this back?
Edit: Found it: developer options - usb debugging
Originally posted by ropo View PostI have enabled debug mode. Removed the Nexus from the device manager. Now it is showing MTP USB Device. I switch it on with the toothpick in AV and I see a device in loading mode. Now I flash TWRP. It reboots and "Nexus 10" is back in "Portable Devices". I want my adb mode back! I boot wasser, then into recovery. TWRP is working. Some pixels cut off on top of screen but working. Yeah! Creating a backup. 1GB. Should have bought a faster sd card. I swithed off the checkbox in "Connect to PC". Still no adb mode. How do I get this back?
There are currently 2841 users online. 0 members and 2841 guests.
