TWRP 2.7.1.0 Custom Recovery - Compatible with R89
Hi !
I was unable to use the TWRP 2.7.1.0, I mean I installed but I can't boot into recovery (tryed 3 apps)
I find this one "TWRP_2.8.7.0_R89_SDcard.img" and it works (with flashify too)
I'm have done a system backup and now, I can try another rom !!
edit:
I was able to backup on external SD,
but when trying to install the wasser 2 or 3 .img files it fails, I get a error:
Image is larger than target device
I try to install on Boot or recovery
any idéas ?
edit:
any idéas ?
Originally posted by Kytrix View PostOk, I'm lost,
I try Rom manager, Rashr, but it doesn't work.
If I understant, the Img file is only for one partition (normaly Roms use severals partitions inside Zip files ?)
I try different version of TWRP, and CWM but this is the only which works (but can"t flash)
Flash from upgrade firmware tab, enable usb debugging in android and enable usb in settings then select flash firmware button to select firmware (.img) then hit switch, then upgrade button.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Thank you for your help, but I'm not runing windows, that's why I would try to flash from recovery (Like I did on all my last smarphones and tablets)
I finaly find a tool working on linux (made by Rockchip apparently)
I find a guide here : http://www.cnx-software.com/2013/11/...ware-in-linux/
It's a little tricky to use because you can't pass directly the wasser firmware to update (this is a glob file containing all partition images, so you have to use another tool to split this image into several images files (one for each partition : system, boot, recovery ....)
once it's done, you can use RkFlashKit to flash all your images.
AND IT WORKS ! My box now running on Wasser lolipop ! too nice !
Thanks.
I could maybe make a topic if somone else is interested !
Originally posted by Kytrix View PostThank you for your help, but I'm not runing windows, that's why I would try to flash from recovery (Like I did on all my last smarphones and tablets)
Thanks.
I'm sure that a guide will be useful to others in the same situation, so go for it.
Originally posted by Smokez View PostJust FYI - I have successfully flashed abduls TWRP Recovery port to the R89 (UBOX 8GB Version)
For those of you that prefer a more familiar recovery, makes light work of flashing zips, and performing full back ups and restores and works flawlessly with all air mouses and keyboards ive tried (TSM~01, Minix M1, Logitech K400)
He also gives us a choice of UI resolutions (optional and may not be required)
1. Download Flashify or similar app...
2. Backup current recovery either to SD Card or optional cloud storage
3. Go to flash > recovery image and select file (TWRP_Beelink_R89.img)
4. Click flash (or Yup!) If I remember correctly.
5. Reboot into recovery.....
You should now have TWRP installed...
It may not be be full screen so you might now need to flash the 1920x1080.zip file via TWRP....
Go to install > sdcard > Downloads (if that's where you downloaded to!)
Return to TWRP Home screen, hit reboot > Recovery and now you should be full screen.
Final Step - Enjoy
All credit goes to abdul_pt - perfect soloution for us beta testers imo
TWRP 2.7.1.0 https://www.freak-tab.de/abdul_pt/TW...eelink_R89.img
HD UI http://www.freak-tab.de/abdul_pt/aml/1920x1080.zip
SD UI http://www.freak-tab.de/abdul_pt/aml/1280x720.zip
Smokez-Chromecast with Google TV
- Android Q Android 10
There are currently 1286 users online. 0 members and 1286 guests.
