Thank you...
Bluetimes RK3288 boxes
Originally posted by Bentalk View PostHi Shomari, I love to try this ROM, if I only flash the "new_boot.img" and "new_system.img", will I lost my apps (application/software inside the current ROM)?
Thank you...
Feel free to try my custom ROM, it has improvements as well:
Originally posted by Shomari View PostIf you flash that way you'll keep all your data. You won't lose anything.
http://www.freaktab.com/showthread.p...tgo-CR12-13-16
Originally posted by Bentalk View PostI am using Android tools 2.3 and only selected "new_boot.img" and "new_system.img" files (the rest is unchecked). AFTER done.. I plug back the power and system boot show with "Android upgrading" Optimizing app 10 of 68 ... I waiting for long time .. System look like hang there... Please advise am k doing any wrong steps? Thanks
Originally posted by Shomari View PostWas your system set on ART runtime? What you're seeing is normal if the system was set to use ART before flashing, that's just the runtime preparing your apps.
Thermal images
I had my measy b4s open, and shot some thermal images of the PCB (playing a 720p movie)
TOP side BOTTOM side
The hottest chip is the powersupply and system controller (60'C). This temperature is normal for these kind of IC's. The RK3288 itself was 55 'C.
Ambient temperature was +/- 25'C and there was no forced air flow.
In this case the PCB was removed from it housing, i think it will heat up 10'C more when it is in its housing. (no holes at all in the Measy housing)
The orange dot on the Wifi module is just a reflection. so no hot spot here..
I would say.. No worries....
Pedorie
[ATTACH=CONFIG]8133[/ATTACH][ATTACH=CONFIG]8134[/ATTACH]
Pedorie
Originally posted by yric37 View PostI think you are not right. My Measy CPU after playing 1,5 hours on XMBC reached 90 C and shut down. The usual working temperature is about 70 C because bad ventilation. I mounted a cooler on a top of box and as resault CPU has a temperature between 35-50 C in all situations.
I also would never buy a RK3288 box that doesn't have adequate ventilation. Even the QPRO can be better designed with bigger vents and better placement.
Measy must have been nuts stuffing the RK3288 in a box without vents.
Pedorie
Originally posted by yric37 View PostThere are very many small holes in the bottom of the Measy housing.
Those holes are so tiny and on the bottom side of the housing. They have no function.
But with your fan on top they do have a function, but still, they are to small.
My test where done without a housing.
The assumption that the housing would add 10'C is a little to optimistic according to your test reusts
Pedorie.
Originally posted by yric37 View PostThere are very many small holes in the bottom of the Measy housing.RK3288 Devices
- Overview BOX (LINK !)
Measy B4S
Originally posted by no_spam_for_me View Post
Originally posted by yric37 View PostYou are wrong. I speak about Measy B4S. Your example - other box, other design. B4S has closed to 400 small holes in the bottom. Pls. be attentive.
You wrote "...because bad ventilation. I mounted a cooler on a top of box and as resault CPU has a temperature between 35-50 C in all situations"
and if you are attentive you would recognise that the pcb is 'up side down' build in, which means, the soc and the heatsink is under the pcb and so they only put vent holes in the bottom...RK3288 Devices
There are currently 1783 users online. 0 members and 1783 guests.
