Bluetimes RK3288 boxes
As for all the different firmwares, that's a huge plus. Plenty users of RK devices wish they had the broad ROM comptatibility this device (the QPRO) enjoys; in the long run it will allow for easy construction of custom ROMs and with additional baked in features/mods.
Shomari,
I like your explanation style.
If you can eloberate on quoted context it will certainly educate us.
Thanks in advance.
Re: Bluetimes RK3288 boxes
Originally posted by 24franklin View Post
Shomari,
Thanks in advance.
That caused a situation where users were stuck (and some still are) with buggy, outdated and flawed firmware; often the firmware that came with the device. That's it. Not a single udpate, not a single custom ROM - nothing.
With the QPRO, it shares ROM compatibility with the Cloudnetgo CR12/13/16, the CS918ii, and the Measy B4S; just that we know of.
So that's four potential factory firmware sets to choose from down the line, which bodes well for users/devs who may eventually want to mod firmwares and make custom ROMs, and it also raises the chances that any bugs/kinks will be sorted out in short order, if not by one manufacturer, then maybe from one of the three others.
Just in the last two weeks alone there have been three fully compatible firmwares released, from three different factories, with different kernels and system files each.
Two interesting observations:
1. The $49 unit has been deleted from Aliexpress, no surprises there.
2. The Bluetimes factory listing has been pulled from the Australian **** site. This is surprising but may be due to **** currently offering 15% off for purchases over AU$50. It will be interesting to see if the listing returns after the sale.
As a consequence of the 15% off the Measy B4S can be currently had for AU$104.54 ..... ****.com.au item #251631015117
Originally posted by OZReddog View Post...Nuby question, how do you back up the original firmware? Do you use the tools as referred to earlier? Is there a tutorial?
first step, befor you do anything, boot direct to the bootloader mode and make your dumps...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post=> http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
[QUOTE=Shomari;226790]Originally posted by pedorie View Post
..no problem! Good luck
I tried to flash new firmware in my b4s, but need some help here..
It the first time i use this tool, and i am not really a software guru...
Connecting the box via USB brings me to
ANDROIDTOOL v2.3 displaying "Found One ADB Device"
maybe it must be in some loader mode???
When i selected all the files for flashing and press RUN.
Its displaying "Match device type failed, stop running!"
These are the files i selected:
Loader: RK3288Loader_uboot_v2.15.bin
Parameter: rk3288-3.10-uboot-data1G.parameter.txt
uboot: NOT SELECTED (default)
Misc: misc.img
Resource: resource.img
Kernel: kernel.img
Boot: boot.img
Recovery: Recovery.img
System: new_system.img (IS THIS CORRECT?)
Userdata: NOT SELECTED (default)
Backup: NOT SELECTED
I did not selected these files:
Update-script
recover-script
new_boot.img
Maybe i am doing something wrong or totally wrong.
Please Help me..
Pedorie.
[QUOTE=pedorie;227323]Originally posted by Shomari View Post
Hi there..
Misc: misc.img
Kernel: kernel.img
Boot: boot.img
Update-script
recover-script
new_boot.img
Please Help me..
Pedorie.
Got it LOADER mode! (hidden switch on de side of the box)
can someone check the other settings and tell me how to proceed?
Regards,
Pedorie
[QUOTE=pedorie;227331]Originally posted by pedorie View Post
Regards,
Pedorie
Originally posted by Shomari View Post...well - take a look at some of the old RK3066 MK models, especially the clones - it was nearly impossible to find compatible firmwares for certain devices depending on their wireless chipset, and sometimes even devices with the same chipset couldn't run the same ROM.
Looking at these evolving rk 3288 TV set top devices , interested to know more about common PCB boards being used by different small/big players in the industry.
Another dimension is about introduction of 4GB Ram in this mixture.would it enhance consumer experience as most mfgs have expressed their desire to mfg and make availible that option too.
Overall come Christmas,there will be lot of new toys to play around.
Many of those clones will have the same PCBa, too. Come December it's going to be an interesting landscape for tv box buyers for sure.
EDIT: the Bluetimes QPRO shares the same PCBa as the Rikomagic MK902ii (a big player), as well as the aforementioned Measy B4S, CS918ii, and Cloudnetgo CR12/13/16 - and they all hit the market at the same time, I ordered the QPRO 8/21/14. The actual clones are the ones that appear post launch, and there are many already.
Measy b4s
I currently got a measy b4s. Have tried flashing bluetimes QPRO firmware. After which wired connection no longer works. Although able to get ip address, no internet access. Wireless is fine. Flash to cloudnetgo cr12 0827 firmware which works great as its compatible with Measy B4s
There are currently 1915 users online. 0 members and 1915 guests.
