Teclast P90HD RileyROM 1.0 [RK3288]
    ls.txt
      Can you please test this - https://www.freak-tab.de/abdul_pt/TW...TWRP_P90HD.img
      If something is wrong i need log's.
      adb pull tmp/recovery.log if that's not possible reboot to system and adb pull cache/recovery/last.log
      if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
      then mv $user.contact.up.post /.trash; set response($response.type = ignore);
      $user.up.post.ignore_in_future = true; fi;
        Originally posted by abdul_pt View Post
        Can you please test this - www.freak-tab.de/abdul_pt/TWRP/Specifc/TWRP_P90HD.img
        Doesn't work for me. Boots into TWRP and then nothing. Touch is not working. Can't do logs as adb isn't working. However, I managed to get the log from cache (see attached).
        Re - a'Bherraidh
          ls.txt
          Sorry, I was drunk earlier and posted the wrong file in the last post. This is the right one. Let me know if you need anything else.
            Try this one and i need the last.log and the dmesg.txt that should me on cache also, please.
            Boot to recovery, test if it's working, and then if it's the same boot to android and do 'adb pull cache/recovery/dmesg.txt' and the same but for last.log.
              No joy. Tried also with an usb mouse ... but nothing. There is no dmesg log in /cache/recovery. Attached the last.log.
              Re - a'Bherraidh
                Hi
                Please the owners can anwswer :
                1 Has teclast the battery drain issue like pipo tablets have ( i refer to 3g process draining battery in stand by ,eventi in only WiFi pipo tablets)
                2. Is there the other huge issue of pio tablets: danger of bricking if the tablet fully discharge
                3 How is battery life( screen on and stand by)?
                4 how is emmc performance? I read it is slow so slowing down sentire system.
                5 does HDMI work?
                6 dose miracast work?
                  Hey devs,
                  I would be delighted when you could bring the TWRP to live! Something I can do at my end?
                  Re - a'Bherraidh
                    Can anyone test the firs 4k video and other video from http://www.elecard.com/en/download/videos.html
                      Are all you guys able to rotate the device in both ways for landscape? It will auto rotate every way except in landscape with the camera to the right for me.
                      Don't know if it's a bug in the rom or just my device. Also using a sensor testing app, it says the orientation sensor isn't working, it says only the accelerometer (gravity sensor) is.
                        R: Teclast P90HD RileyROM 1.0 [RK3288]
                        Try nova launcher and test it.
                        Please can you test video file above?
                          I am already using Nova. Those videos wouldn't let me use the hardware decoder with mplayer. Using software they were choppy, even 1080p. It must not like the video format.
                            for rotation maybe there is an xposed module ( app setting)
                            abou videos: can you try internal video player? have you tried in mxplayer hd decoder ord hd+ decoder? it is strange you do not have hardware devcoder, because tv box rk3288 can do that
                              I already tried any module. It will not auto rotate in that direction.
                              The videos would not play in the internal HD app. There are no apps called HD decoder in the play store. Those mpg 2 files are weird.. Who uses that? Plus they were named as txt files, I had to rename them to mpg to even get them to work...
                                i mean in mx player hw and hw+ decoder option...
                                so if those file are weird, have uou tried any 1080p and 4k h265 videos. do the play??'
