Teclast P90HD RileyROM 1.0 [RK3288]
    Originally posted by abdul_pt View Post
    There isn't a graphics.c
    You have to mod the device tree to suit your needs.
    Tapatalked
    Ok, fine. That's a bit more complicated then I know it from my mobile. Where can I find the device tree for rk32 CWM?
    Re - a'Bherraidh
      Hey abdul_pt,
      May I ask again where to find the device tree for rk32 CWM you used to compile the recovery.bin?
      Re - a'Bherraidh
        Please help me !!!
        Hi Randy.
        I bought a Teclast p90hd and i flashed the rom in it but the rear camera is not active. Then i flashed a Oma's rom. Unfortunately, it was bricked. It always restart at the logo. I have tried connect the cable for flashing again but it can not connect the flash tool anymore.
        Please help me. Can you let me know how to fix it?
        Thanks a lot !
        These are 3 pics. Randy take a look, please. :-)
          Originally posted by peace View Post
          Hi Randy.
          Thanks a lot !
          Hard power off (press Power until screen goes black). Then press Power and Vol+ until AndroidTool shows “Found”. Then LowerFormat before Run.
            I sent the tablet to a tablet center. :-(
            By the way, thank you so much neojin29. :-)
            Hope i can fix it by myself next time. I've learned good experience from all you guys.
            Best Regards.
              super binary Update
              Hello all, I have an issue... SuperSU asking that I updated the binary, when I try to update it, it fails to install. Any advice would be greatly appreciated.
                Try updating the SuperSU app via Google Play Store and see if the new version will install the binary.
                Randy
                  It worked! thank you!
                    Hi rrileypm!
                    Any news of the 1.26 ROM UPDATE?
                    Thanks for reply
                      Send me a link to it and I will try to cook up a ROM in the next few days.
                      Randy
                          Thanks...I will download it tonight.
                          Randy
                            RileyROM v1.1 is now available here:
                            Randy
                              My new Teclast P90 HD doesn't turn on
                              I have just received a Teclast P90HD from Banggood.
                              It seemed that everything was allright, but when I tried to turn on the tablet it didn't turn on.
                              I left the tablet charging during all the night, but when I tried to turn it on during the moorning the tablet didn't turn on.
                              I used the charger in other of my tablets and it works so it is not a problem of the charger and it seems it is a problem on the tablet itself.
                              When I connect the Teclast P90HD tablet to my PC it seems to recognize in some way the tablet and install the requiered drivers since two new disc drives appear but I got no acces to then.
                              I have recorded two videos:
                              1) It shows how the Teclast P90HD tablet it is not charged and it doesn't turn on with the charger conected to the usb port, but when I connect it to my ASUS tablet it works
                              2) It shows that when I connect the Teclast P90HD tablet to my PC it seams to recognize in some way the tablet
                              I have tried to upload them but it says invalid files (they are in mp4 format)
                              Please could anyone help me.
                              I would be very grateful since it was a present for my children.
                              Thanks in advance.
                                Thanks in advance.
                                From the sound of it you may have received a defective product, or in other words DOA.
                                When the tablet is plugged in... Does a battery icon appear on the screen? If not, then the device is dead and you'll need to return it.
                                Are you holding the power button when attempting to power on the device? Usually 5 seconds.
                                Try holding the Volume + and the Power button at the same time for about 10-15 seconds.
                                Sorry to hear about your problem. I ordered my Teclast from Banggood.com as well and it worked fine. Hope that you find a solution to this issue. Good luck!
