Teclast P90HD RileyROM 1.0 [RK3288]
P90Hd
I just received one of these from Geekbuying. Seems very nice, so far.
Would anyone be able to advise how to access the recovery?
Is there a TWRP available yet?
I don't even know how to back up the stock rom yet.
There are several Chinese apps that were disabled out of box...Anyway..a new rom is warranted.
Is this thing adb only right now?I see Riley Rom is based on the rom mine is running.
Does it or the same?
Thank you for your kind replies,CS 918-k-R42Wasser 4.4 v1.04(old) W/Omniswitch
Rii i28 (love it)
B&N Nook HD+ --PAC ROM 4.4.4 RC2
Teclast P90HD
Riley 1.0
How much total NAND is on the tablet? There has to be at least enough room for the system...and userdata partitions. 12gb may be too much...so try 8 or 10.Randy
Hey guys.
Does anyone else have a problem with the touch screen where after touching the screen some times - one of every 30ish touches - the screen keeps detecting the last touch? That is, some times, after lifting my finger after a touch, the touch screen still detects that my finger is touching the screen. Does anyone else have this issue?
Also, I'm getting a lot of stuttering and jittering when navigating the UI. Is anyone else having this issue where it's not as fluid as it should be? Do I have a faulty unit?
Thanks, and I'm hoping for TWRP/CWM soon!
Originally posted by abdul_pt View PostYes, I have it working(more or less on my test device). Currently can't get both sdcard to work, only internal or external at a time. Don't know if I can make it work, I believe this is how CM has storage defined(data/media) and I can't seem to bypass it or I don't know.
Re - a'Bherraidh
I've only made one version...1.0.
If someone can send me a ROM dump of a newer firmware...I can make an update.Randy
i have d/l: P90HD (A6K6) -Android4.4.2-V1.24-4123.rar
is it helpful?
UpdatedSoftware NameVersionTelecommunicationsNetcom2014-08-26P90HD (A6K6) Android 4.4.2 firmware downloadAndroid4.4.2-V1.24Originally posted by rrileypm View PostI've only made one version...1.0.
There are currently 1624 users online. 0 members and 1624 guests.
