Polariod PMID701i, PMID701i_10, PMID701_x10, PMID701c, CM9 / AOKP /CM10 compatibility
    Originally posted by [email protected] View Post
    CM10 Files need:
    from CM10 folder - CM10_Polaroid-PMID701c-Trial-20120914.zip...
    BTW, this file doesn't want to download (perhaps corrupted?)
    https://public.bay.livefilestore.com...ion.png?psid=1
      Re: Polariod PMID701i, PMID701i_10, PMID701_x10, PMID701c, CM9 / AOKP /CM10 compatibility
      Would you like me to upload the zip for ya? Just let me know which files you need.
      Sent from my Admire running Lazy M6 with Tapatalk
        Um.....CM10_Polaroid-PMID701c-Trial-20120914.zip :-)
          sorry I thought I had that version, all I have is the CM10_Polaroid-PMID701c-Trial-20120914-LITEv0.1a.zip and CM10_Polaroid-PMID701c-Trial-20120914-LITEv0.1b.zip, but since 1a worked, I used that one
            oh ok...good to know...thanks!
              you're welcome...
                Other problems:
                • Wifi Hotspot doesn't turn on.
                • Clock on lock screen cut off on right.
                • Tapping the clock in the lower right intermittently works to show settings menu.
                On another note I haven't seen Wifi not waking from sleep in a while...
                  Any chance we can see compatibility zips for CM9?
                    Works Great
                    Thank you CM10 is working great on my PMID701C and I am very new to flashing tablets.
                      Yeah you will I'm in the process now of clean my base structure and naming scheme expect by the end of next Monday.
                        No new compatibility zips will be posted until Monday, i was hoping to post one for the 4311 and a fix for the 701iX13 TS before then but i really need to focus on cleaning up my bases. With that being said, along with cleaning up the base files ill be cleaning up my Google Drive structure, and starting a new thread to house all them under. so keep a look out Monday 9/24/12 for the new thread, and yes for those wanting to know CM9 and AOKP compatibility ZIPS will be posted for 4311 and 701 series then too.
                          I was going to flash CM10 on my 701C until (after reading the thread) I realized there was no way to change volume via the software controls on the taskbar (like GB)...
                          I think I'll wait until that's restored....
                            Can't wait. It's exciting to see what this tablet is capable of with your help.
                              when i post the CM9 and AOKP-ICS compatibility zips, AOKP does support this function.
                                Cut-off clock and system menu not working
                                Ok so I feel a bit like a newb now but I was using Nova Launcher when I reported the clock on the lock screen being cut-off, in this rom, and the system menu in the lower right not responding. Went back to Trebuchet and all is working.
