Polariod PMID701i, PMID701i_10, PMID701_x10, PMID701c, CM9 / AOKP /CM10 compatibility
sorry
new compatibility zips will not be posted now until Wednesday evening at the earliest now, i'm really sorry, i forgot my thumb drive at work Friday, so i built them based on my notes and put them on my sdcard on my tablet, sadly i messed up and formatted my sdcard by mistake so i have to redo them again.
it seems that allwinner development has come to a end for now from the communityso with this last set of zips i hope to add support for all the Allwinner: Cyanogen and AOKP based roms i know of. (hopefully some manufacture will release an official jellybean firmware so incomplete proprietary files can be charry picked and maybe interest dev to some more building.
so as of now it looks like on the list for support is.
Christian Troys: CM9, AOKP, CM10
Quarx2k CM9, CM10
Cyanbook V0.4
Kangbook
Cyanbook_JB
if you know of any other CM or AOKP allwinner based roms to look at let me know, again sorry for the delay on these compatibility zips.
Originally posted by [email protected] View Postnew compatibility zips will not be posted now until Wednesday evening at the earliest now, i'm really sorry, i forgot my thumb drive at work Friday, so i built them based on my notes and put them on my sdcard on my tablet, sadly i messed up and formatted my sdcard by mistake so i have to redo them again.
Quarx2k CM9, CM10
Cyanbook V0.4
Kangbook
Cyanbook_JB
Potential CM7 Rom: http://www.androidtablets.net/forum/...k-edition.html
The P76ti tablet seems to have some similar hardware. Backing up my data now and will see what works out of the box if anything with this rom.Last edited by drywall420; 27 September 2012, 21:27.
sorry been gone for so long.....
sorry for the long delay every one, my crash of my sdcard left me with alot of work to fix. i hope through out the day to be able to post compatibility zips as well as my first build of the CM10 for Allwinner Devices, it seems adding volume control to the navigation bar is a must for most people so i'll add it in to my next release.
Originally posted by [email protected] View Postsorry for the long delay every one, my crash of my sdcard left me with alot of work to fix. i hope through out the day to be able to post compatibility zips as well as my first build of the CM10 for Allwinner Devices, it seems adding volume control to the navigation bar is a must for most people so i'll add it in to my next release.
Originally posted by [email protected] View Postgonna be a bit longer saw southerntelcom posted new firmwares now going to re base off there newer kernel build.
Originally posted by [email protected] View Postsoon. extracting southerntelcoms lastest firmware updates as i type.
Not that it matters I still run Onda firmware anyway for the wifi hotspot feature.
follow this order for flashing ROM to device,
(1st wipe device so our install is clean)
select install zip from sdcard
select choose zip from external sdcard
select ROM_WIPER.zip
select Yes - Install ROM_WIPER.zip
(2nd install CM9 / AOKP / CM10 BASE)
select "highlight your downloaded CM9 / AOKP / CM10 ROM"
(3rd install Compatibility Zip)
select choose zip from external sdcardfor CM9 / AOKP select: PMID701series_CM9-AOKP_BOOT-trial-1.zip
for CM10 select: CM10_Polaroid-PMID701c-Trial-20120914-LITE.zip, try with this one first, i don't own this device i cant test. (skip to step 5)
(4th install su binary CM9 / AOKP only)
select su-bin-3.1.1-arm-signed.zip
(5h install gapps)
for CM9 / AOKP select: GAPPS-ICS-07092012.zip
for CM10 select: gapps-jb-20120829-signed.zip
(6th install FORMAT_INTERNAL_SDCARD.zip)
select FORMAT_INTERNAL_SDCARD.zip
(7th Factory Reset)
select Go Back until you get to 1st Recovery Screen
select wipe data/factory reset
select Yes - delete all user data
(8th Reboot)
select reboot system now
(9th Wait)
1st boot takes a minute be patient let it sit and do its thing i personally recommend at this point you take a 15 minute break grab a cold one and relax and let the device build its cache and settle down. you will need to change the background image as it doesn't draw correctly the first time.
There are currently 2955 users online. 0 members and 2955 guests.
