I wonder if William will use Shaun's CM10, from Slatedroid. I guess Shaun took over from Christian Troy, and is currently compiling 4.1.2 for us.
Polariod PMID701i, PMID701i_10, PMID701_x10, PMID701c, CM9 / AOKP /CM10 compatibility
Originally posted by jacodaburr View PostCWM-based Recovery v5.5.0.4
On screen buttons DO NOT work...
Can use the side buttons to move up and down, but cannot select anything...any suggestions?
Power button = main menu
Home button = up (or is it down?)
Menu button = Down (or is it up?)
Back button = execute menu option
Power button = does nothing
Home button = up
Menu button = does nothing
Back button = down (I actually think this is the G-Sensor button?)
Home button = up
Back button = down
Originally posted by elektrik View PostTry holding the 'back button' down or maybe press it a couple times...-maybe too light on the pressing? Dunno, never had that problem...
Does the battery charge level have anything to do with it?
EDIT: Will the 701i 10 support any other version of CWM, preferably and earlier version?
Originally posted by jacodaburr View PostI have no idea, what to do. None of the onscreen buttons work in CWM, and only two of the four buttons on the side work, Home and G-Sensor(??)...when I press the Home or G-Sensor button several times (cycling through the main screen of CWM) it will tell me Back menu button enabled, and continue the process will eventually say Back menu button disabled...I have no idea what is going on here...wish I could use TWRP instead of CWM...
Originally posted by elektrik View Postand you're SURE the back button doesn't work if you press it more than once or slightly more firmly? I noticed my back button doesn't work if I press it lightly. It actually acts 'differently' from when I press the home or menu buttons (I just tried it)....
Pretty sure I'll break the screen if I press any harder, lol
Originally posted by jacodaburr View PostPretty sure I'll break the screen if I press any harder, lol
Originally posted by elektrik View PostHm...then I got nothing-maybe reflash to stock and try the process all over?
Originally posted by jacodaburr View PostWell I am still on stock...haven't gotten very far :-/...once I got back into my tablet I installed the KK Romkit, opened the application and just chose Install CwM Touch...once it finished I chose to Reboot into CWM...that was when only 2 of the buttons would work and none of the on-screen. I mean I can press the on-screen and they will go red (from white) but they do nothing...can I flash an earlier version of CwM?
Originally posted by elektrik View PostNot sure, but when I said start the process from scratch, I meant the WHOLE process from scratch-including re-flashing the stock ICS and then reinstalling the apk/CWM
Power button and Menu button do nothing
Home button is 'up' and back is 'down'
None of the on-screen buttons work.
Originally posted by jacodaburr View PostI gave it a shot, and alas still the same issue...can anyone else help with this issue? Anyone else experiencing the same problems that I am experiencing?
KKRomKit V1.22
*note even though I had success with gingerbread with this apk versus the other apk. it's not to imply that this does not work with ICS*
There are currently 3649 users online. 0 members and 3649 guests.
