I tried you compatibility zip on CM10, and it just flashed the polaroid screen and went to a lit black screen. so thats no good. looked in the zip, and found you were adding apps, and su. If you try another one, maybe concentrate on getting the hardware to work first, then add apps and what not. I know CT's CM10 will boot, but the touchscreen does not work. So I would think just getting the hardware to work properly would be a priority. Just saying, but I want to thank you for your work...I have a 701c A10 so the X13 shouldn't be a problem with me..also if you get one to work with the 701c, it will work on the 701i. I was running the ICS rom from the 701i on my 701c
Polariod PMID701i, PMID701i_10, PMID701_x10, PMID701c, CM9 / AOKP /CM10 compatibility
william,
Originally posted by [email protected] View Postplease post your model and does this happen with both CM9 / AOKP, or just with the CM10. if it is with both i will rebuild one just for that device and not the full 701 series. also the 701i-X13 model wont work. if it is the X13 model try the 702c compatibility.
Originally posted by [email protected] View PostAlso make sure u use the correct compatibility zip there is one for CM9 / AOKP and a completely different zip for CM10.
I have a 701i-x10. tried cm9,cm10, and aokp all with the same result. my tab shows the polaroid logo then a blank lit screen then loops back to the logo.
Google Doc's is opening the zip for the CM10_Polaroid-PMID701c-20120904.zip, not allowing the download
Originally posted by rusty2788 View Postit boots up but cant turn on wi fi screen dosnt rotate this is on cm10
Originally posted by jtintle View PostGoogle Doc's is opening the zip for the CM10_Polaroid-PMID701c-20120904.zip, not allowing the download
Originally posted by [email protected] View PostOn rotation please check Nova setting normally disabled by default. For wifi reload ICS run lsmod with wifi off the turn wifi on and run lsmod take notice of what module is added locate .ko for that module in /system/lib/modules reinstall or restore CM10 paste that module in system/vendor/modules/ reboot see if wifi turns on. Is touch screen working? Please post what modules loads in ICS,
i have been running the cm10 rom for a few weeks with the momo 9 zip on ct page on slate d
ok gave it a try,
Touch screen works, but no rotation. I can force it into Portrait mode, but if I turn on auto rotate in nova and and in the system it does not rotate...
Wifi is not working, this may help, shawnbusker said the 701c was using the rtl 8192cu.ko & mma7660.ko drivers for wifi, its in thread:
Also the accelerometer for the 701c is a freescale accelerometer - 263 7660 3JVM from this teardown thread:
with a link to the freescale site in it,
EDIT: I don't think the sound is working with this. None of the notification sounds work,
"(3rd install Compatibility Zip)
select choose zip from external sdcardfor CM9 / AOKP select: PMID701series_CM9-AOKP_BOOT-trial-1.zip
for CM10 select: CM10_Polaroid-PMID701c-20120904.zip (skip to step 5)
select Yes - Install"
I cannot locate the PMID701series_CM9-AOKP_BOOT-trial-1.zip, am I missing something?
Thanks, Great work btw!
Im not doing any more work on this device until i find one for sale on craigslist..... Sorry
There are currently 2526 users online. 0 members and 2526 guests.
