And i did the buffers mod too.
TV110 Android Tv Box
Originally posted by dracosc22679 View Post
And i did the buffers mod too.There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by csgabe View PostAMLinux/OpenELEC test for TV110:
http://xbmc.ru/forum/showthread.php?t=4587Originally posted by Claude View PostThere are bugs:
In dmesg constantly falls - aml_dvfs_do_voltage_change, no dvfs driver
The screen resolution is only 1280x720
Maybe something else.
I flashed it to my X4 box and it works really well. XBMC is super fast compared to the Android version. The only problem I've got is that mini-display preview in LiveTV is not centred, but that's still not fixed in Kodi for Android either. It uses 14.0-beta3, and wifi, h/w decode, passthru, etc. are all working fine and the GUI is lightening quick. I haven't tried 1080p, but my tv is 720 so I don't care if it doesn't work. I need to do a bit more testing, but it seems great so far.
By the way, I used Daemonium's TWRP for the TV110 to flash the ROM
Originally posted by csgabe View PostYes, I've tried it (Openelec). It works good, but I didn't like 720p resolution, it would be ok if only menu would be 720p & it would do automatic resolution & framerate change based on video source.
Originally posted by csgabe View PostYes, I created a bootable sd card, but you could try to login into the openelec box via ssh, then issue "reboot recovery" command.
1080p Openelec
You can change 720p framebuffer to 1080p in Openelec via a script that's run on startup:
Login through ssh, run the following command:
Code:nano /storage/.config/autostart.sh
Code:echo 1080p > /sys/class/display/mode echo 1 > /sys/class/graphics/fb0/freescale_mode echo 0 0 1919 1079 > /sys/class/graphics/fb0/free_scale_axis echo 0 0 1919 1079 > /sys/class/video/axis echo 0 0 1919 1079 > /sys/class/graphics/fb0/window_axis echo 0 > /sys/class/graphics/fb0/blank echo 1 > /sys/class/graphics/fb1/blank
I have instaled the version of openelec listed on this page to my tv-110 but can not conect to the internet making my box.... well useless as i can no longer boot to recovery to restore android ether
the box sees both the wired and wireless connections but wont conect to ether
any help on getting the wired or wireless to work or re flash android would be greatly apreciated
Originally posted by daemonium View Posthi guys, i was trying to port twrp to tv110 and it was being a little hard. so, i asked my team mate Abdul_pt for a little help. Now i have a working version of twrp for tv110 and also for s85 and MXQ. I figured out how to load it from sdcard, so yes, no need to flash.
Now i need a/some brave man/men to test this. I already flashed it on my tv110 , it looks like it's working backup, restore etc, but didn't test further.
Anyone?
Hi
Could i get a copy of your twrp for the tv-110 to ether flash or boot from sd to help rescue my box please
Ps i am using your modified rom on my other 110 its working great
There are currently 3458 users online. 0 members and 3458 guests.
