Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
    Finless for mx3 1g??
    Finless are you going to make a rom for the mx3 1g?
      First, i want to say i muchly appreciate all the work done on Finless 2.0
      Now, i have 2 devices running this rom and so i have the known Mac-adress conflict running them both on Ethernet. The wifi performance is way too bad.
      I tried Omen's sollution but it didn't work, cause the device doesn't connect.
      Do i need other drivers for a device running on Finless 2.0?
      Or is there an easyer way to solve the problem?
      I've got a Beelink S82 8gb and a MXIII 2gb/8gb
      Thank you all in advance.
        Re: NEW - Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
        We have the same boxea hope theres an answesr
          Having an issue since going to this rom. I was watching an ISO Blu-ray rip last night. Every 30 minutes it would speed up the video but the audio would stay the same. Only thing I could do get back in was stop the video, restart from the beginning then skip forward. Tried restarting where I was, it froze the box.
          Has anyone else experienced this?
            Hulu and HBO Go Problems?
            im not having the same problem but HBO go will log in and almost play but then thinks for a few min and then says cannot play also Hulu plus app will play but every few commercials or so it will crash and I have to restart the app. I did have a moment where hulu was doing something to speed up the content but all i had to do was restart the app. I received this box from a friend and it had a early version of this ROm on it so I updated but from my understanding he has had it working with HBO Go in the past. Has anyone else had theses problems on the 2.0 update of Finless or do you hav e Hulu and HBO go working without any problems??
              Well bob oman gave us a xmas gift hope finless rom will be released for the 111k4
                What? Can't run 2 boxes on same ethernet network? That's nice to know since I wanted to buy 3 boxes!
                  => http://www.freaktab.com/showthread.p...l=1#post261792
                  RK3288 Devices
                  - Overview BOX (LINK !)
                    Does this ROM have the wireless PS3 controller support build in? (without the need of installing the sixaxis app from the playstore)
                      There will be an update to this rom if u all are not awear there has been a release from beelink 111k4
                        Hay, first thankyou for making this great fw, i used this because only your rom supported sixaxis
                        I use beelink mxiii.
                        So btw i have Chinese clone gamepad which is dragonrise usb gamepad (device ID 0079:0011). i connect it with otg cable.
                        the problem is only navigation pad and two button recognized. i tried using gamepad tester and look into the keycode which is keycode 0 for button that doesn't recognized. i test the gamepad using samsung galaxy tab 3, all button is working and it show the keycode. i think maybe on the box is missing the driver ? i looked into google, there is module named hid-dr.ko this module used specific kernel version so i can't use module from other device. I'm asking can you compile that module for your rom please that would be great if the button show the keycode instead keycode 0, from that on we can use keylayout to map the device.
                        Thanks!
                          Thanks!
                          Hi, Can you maybe confirm if sixaxis support is for wireless support and not with cable?
                            Yes sixaxis will work as long as you use the sixaxis app 8.0 or above.Older versions will not work
                            https://play.google.com/store/apps/d...ntroller&hl=en
                              I meant without using the sixaxis app. Is this not or can't this be built in a Rom directly? I thought finless had build in Ps3 controller support in his roms?
                                Arrrr sorry you will always need the app in any & every rom theres no way it can work without the app,The surport added by bob enables the use of the app (drivers ect)
