Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Originally posted by Pinocan View PostCan I use this rom also on the Mbox S82B?
ThanksPlease consider making a Donation to freakTab
NEW - Beelink S82/S82H/M8 & Tronsmart S89/S89H - Finless 2.0 ROM
Finless, is any reason for Bell TV Work in Other Roms and not on yours? http://www.freaktab.com/showthread.p...l=1#post238998Last edited by tiguy82; 21 October 2014, 00:13.
Same problem of non-ended boot animation.
I've updated from 1.8 and after finish burning the first screen shown and then when the Filness ROM/Freaktab.com animation shown its just stuck there for long long time.
tried to REFASH (3 times).
tried to wipe data : same.
Now I installed 1.9 : there everything looks grate exept one thing : every reboot the device is wiped data and back to new .
before i'm going to invest more time - is there an option to fix one of these problems?
Originally posted by MikeD View PostMaybe you still have the sdcard inserted and it automatically flash the rom every restart?
b. after a few times i re flash the 2.0 but i checked the wipes checkboxes in the update app.
finnaly its looks to works fine and eve after reboot.
thanks anyway.
Originally posted by bouhady View PostI've updated from 1.8 and after finish burning the first screen shown and then when the Filness ROM/Freaktab.com animation shown its just stuck there for long long time.
Originally posted by bajann View Post+1 i have that problem after i reset to factory finless 2.0 no way to fix that
1. burn 2.0. (endless animation )
2. reburn from recovery (tooth pin reset without the aml file). (still endless animation )
3. reburn again. (still endless animation)
4. burn 1.9 from recovery. the boot finish well and the system goes up BUT new problem shown : its hard reset every boot (all new apps/settings deleted every reboot).
5. from "Update app" (in 1.9) - flash 2.0 BUT check both wipe checkboxes (data+media).
done. (at least for me).
Edit: well according to resolution changer I am at 1080p. Icons, wifi symbol, etc are all rather fuzzy..
Maybe a stupid question but how do I change the resolution to 1080p? In the stock tronsmart launcher there is an option, not in settings though where it is with 4.2.2.
Everything is looking to be at 720p no matter what I change.
Originally posted by Genem View Postyou can find it in the mbox settings under display.
The finless rom image on boot looks clean and crisp, better than any image in actual android...
There are currently 1794 users online. 0 members and 1794 guests.
