Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
I'm really not sure, only an idea, but maybe it helps to close XBMC before standby....RK3288 Devices
- Overview BOX (LINK !)
Originally posted by mattyspurs76 View Post
Anyone recommend a zero cache file? So many to chose from.
Tried many zero config files but it seems none of them does the job.
Still have to deal with buffering issues from several sources.
Originally posted by mattyspurs76 View PostLove to know what's going on with my posts on here.
Anyway, great rom, works great on my beelink mxiii 2gb. I'm also using stann1983 Xbmc and Wow.... Awesome. Job and my box is stable now.
Anyone recommend a zero cache file? So many to chose from.Originally posted by FrankyH View PostThis is something I would like to have an answer on it too.
Issue digital audio auto-detection and passthrough
Hi Bob,
when i choose in MBOX-settings Advanced>>Digital.audio.auto-detection >on<, the Digita.Audio.Output will automatically set to "PCM", and this is not changeable.
I want to play normal Audio by HDMI-Port. When activated passthrough in Kodi_Helix, i want to used SPDIF-Port, for files with e.g. DTS-Audio. But this is impossible, because in MBOX-Setting is value "PCM", change this value without auto-detection to "SPDIF Passthrough", it won't played Audio by HDMI. On finless1.9 ROM this worked very well. That is why i go back to finless1.9.
Please take a look on this; hopefully you can fix it.
greets
bergi
HI BOB. THANKS A LOTfor this rom.works very fast on my vega s89 standart edition. i can confirm better wifi connection. i use only wifi
apps full screen. system stability great. antutu 40.200 incredible results
only problem for me is: i use hide it pro or audio manager app to hide native apps wo iusses.
but in 1.7 1.8 1.9 2.0 roms this app dont work. superuser not compatible with this app. i dont know why?
audio manager works fine in 1.4 1.6 roms.
NEW - Beelink S82/S82H/M8 & Tronsmart S89/S89H - Finless 2.0 ROM
GREAT ROM BOB - THANK YOU - I am new to all of this including posting in forums so I apologize in advance for any breach of protocol.
Tried to install the CPU fixers as well via methods 1 & received error message so tried using the mouse work around. Can't get any control from the mouse at all so that I can select "Apply updated from EXT". Is there some setting or other trick to get the mouse to work rather than the infinite scrolling I'm seeing?
Thanks in advance!
Originally posted by Cak123 View PostGREAT ROM BOB - THANK YOU - I am new to all of this including posting in forums so I apologize in advance for any breach of protocol.
Thanks in advance!
Make sure the mouse is plugged in before you boot to recovery. Recovery is a simple OS level and cannot detect a mouse being plugged in after it has loaded.
Originally posted by Finless View PostWhat kind of mouse? Use a USB mouse but I will say my wireless 2.4 mouse (with USB dongle) also works.
if the mouse is not plugged in before the boot recovery it will not pick it up must be plugged din before.
JustMeBugs are Sons of Glitches!
JustMe
For some reason 1.8 worked perfectly for me, but when I tried to upgrade to 1.9 and now 2.0 suddenly xbmc and youtube no longer work properly, there is no sound and the video looks choppy.
Am I missing a setting or something I need to change?
Thanks.
EDIT: The problem may just have been Kodi XBMC. I rebooted the device and youtube started working. I tried a different video file and it seemed to work but then another didn't. I reinstalled gotham 13.2 and everything seems to work now. Shrug.
On a sidenote, are there any settings I should be changing in xbmc to get the best palyback?
Thanks againLast edited by portezbie; 02 October 2014, 03:36.
something weird is happening i just opened youtube app and now it won't display videos, i get black screen and audio. Itt's not been updated and i cleare cache and data of the app but same thing. Before i unmount my external hdd and reboot i would like to know if anyone else has experienced the same.
Anoher thing. i have tested 3 movies now with and without amcodec enabled. i press "o" while playing the vidos and the difference alot between skipped (mostly) and droped (very few) frames.
With amcodec on i would get 0 droped frames (even after pause/play delays) and hundreds of skipped frames, with amcodec off i get droped frames only when i pause/play sometimes and very few (less than 10) skipped frames after haviing watched a whole movie BUT visually speaking i saw no difference between the two.
My question is should i leave amcodec off and not worry about my box die/fry, i don't know if it can affect it considerably but i've got a feeling.
There are currently 2286 users online. 3 members and 2283 guests.
