Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Originally posted by trewis View PostHi Bob!
I love your work and your roms for the amlogic devices!
You make using these devices a lot better and inprove their usability.
I have one little problem with your latest 2.0 rom:
Toslink seems to be deaktivated by default, I found no way to switch it on in settings.
HDMI passthrough is aktivated by default, which works perfect, but when I like to only hear music from an iternet-radiostation, i dont want to switch on my tv to do so.
In your last rom, I could use toslink to hear internet-radio using my 7.1 receiver without hdmi.
Maybe there is a simple solution to this problem or I can't find any?
Greetings from Austria
Werner
Originally posted by Targeter View PostOk I fixed my problem. I *think* I was missing restore.img.
What I ended up doing was installing AMLinux (that install would boot, which is why I think restore.img was the key) and then re-flashing to Finless 2.0. Everything works just fine now.)
Originally posted by bajann View PostPlz just try to reset to factory ,i need to know is it ok for u or not (my box stuck with finless logo)
If you did a factory reset without a twrp backup you have nothing to loose.
I'm pretty sure if other users read your problem they won't wanna chance doing the factory reset....Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
I'm pretty sure if other users read your problem they won't wanna chance doing the factory reset....i dont know why? i go back to 1.8finless and all is ok, but 2.0finless stuck with logo after reset to factory
i put recovery image and flas all the same like before and when i shutdown box and when power on i have strange mesage on the screen maybe becouse google setings i dont know
i just need to know (only i have this problem or not)sry on my bad eng .ty
Originally posted by bajann View PostOK i 5 times reflash fw and all time same problemi dont know why? i go back to 1.8finless and all is ok, but 2.0finless stuck with logo after reset to factory
Do you do the factory reset from android settings option or the option in recovery menu?
When I was playing around with 109k4 I definitely did data / cache wipe from recovery with no issues, maybe try that....
Also if you message is google voice or speech failed on first boot I got the same thing but it didn't affect the usability of my box.
I won't try the factory reset from android settings though. I can't be bothered to set back up again right now, sorry.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by ant View PostOk, reading back through oman's stock thread, this thread and oman google.doc this firmware still has various bugs. You may have found another?
I won't try the factory reset from android settings though. I can't be bothered to set back up again right now, sorry.)4 metod but now dont go frist boot stuck in finless logo
i power of and i put power back no stuck and i go to recovery but i dont know how to select data ceche wipe is not posible
blue thing go up down all time
my reciver was in usb slot .i give up
Originally posted by bajann View Postnow i sistem update from recovery (i have some problems but i do it)4 metod but now dont go frist boot stuck in finless logo
Originally posted by ant View Post....use stock remoterun stock 109k4 on my second device i dont have problem with stock rom but i dont try to reset to factory
i will try to put 109k4 or maybe 1,9 finless ,i dont know what i do wrong this is frist time to i have problem with fles
i hope beelink can make new rom with scource from latest sdk and i wait to finless 2.1 .i dont want to try more i try about 10 times
BBC iPlayer problems with Finless 2.0
Hi there,
Firstly a big thankyou to Finless (Bob) for the excellent work he continues to do for all of us here.
I have just installed the Finless 2.0 ROM over my original 105k4 ROM and it runs beautifully, and it was so easy to do. I am especially grateful for getting rid of that awful original on-screen keyboard that kept auto-switching to Chinese!!
I do, however, have one or two problems with some UK TV apps, namely BBC iPlayer, 4OD and 5 On-Demand (all these are UK catchup tv apps) no longer display any video. I get the sound OK, but the screen goes black. Annoyingly, the Channel 4 app plays their adverts beautifully, but once the actual programme starts, the screen goes blank!
Is there a way around this?
Would I be better off installing your 1.9 (or Oman's 109k4 rom)?
Any help is appreciated
Steve
StevePlease consider making a Donation to freakTab
Originally posted by Veronica View PostIts happening to me too using this rom, it won't wake i have to manually press the power button. I'm not using stock remote control. i do close everything before standby
i tried "screen will never sleep whilst charging" solution, but it seems OK for short period standby, after one night standby, it still couldn't wake up by ir remote.
With stock Oman rom it didn't work at first but soon started working wake from sleep then i flashed finless 2.0 version when it was relelased and it took forever (weeks) for wake from sleep to work, as i mentioned just few days ago started working.
Don't know what got messed up, im NOW having also a problem with android media process it starts crashing one time while watching a movie in SPMC, also Youtube app is giving constant error that video could not load please try again and i have to clear data of "media storage app" to make it play videos again.
I also experienced one freezing while opening Settings from Mbox Home laucher and another freeze while watching a movie in SPMC ; video stopped/froze and audio was in a loop, the box was unresponsive to any key button so in both ocations i had to force power off the box.
I don't know if problems mentioned are ROM specific or new SDK bugs (for a change).
ANYONE ELSE FACING THE SAME PROBLEMS?
There are currently 1409 users online. 1 members and 1408 guests.
