Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Having some problems with Finless 2.0, compared to Oman's 109k4 :-
I've attempted several clean installations of the Finless rom but get the same issues every time. I've gone back to Oman's 109k4 for the time being.
-Apps drawer: Laggy, compared to 109k4 which is smooth.
- Cannot change wallpaper to a gallery picture (crash) - bug also present in Oman's rom, although works fine with wallpaper gallery selection.
- XBMC Helix (which Bob has linked) crashes during initial startup.
After initial startup crashes during SuperSU messages.
Disabling the messages within SuperSU allows startup without crashing.
- XBMC Helix issue itself: Acestream parsers cannot be added (menu item not selectable)
- XMBC Gotham (provided in Finless package) runs fine, Acestream parsers can be added.
Although, occasional crash. Crashes not seen at all when using Oman's 109k4.
...just reporting what I've noticed so far. Appreciate your hard work Bob.
I have no crashes with Kodi and Superuser.
I watched about 5 movies straight last night and not one crash.
I think your box has some problem.
install problems
I am having a problem installing 2.0 on my system. I never had such problem thus far. Everytime has worked on the previous updates. I tried method, 1,2 and 4. None of them work. It goes to recovery and then installs and then when it reboots it goes to a black screen. Nothing happens. It does not boot.
Anyone seen this ?Using a Tronsmart Vega Elite S89.
installed this one over the 1.08 using the SD methode without problems. No need anymore to adjust screen to 91%. 100% is now perfect.
Helix is crashing all the time so I use SPMC. on 1080p 60hz, almost no more drops or skipped frames. im happy now. thanks finless for yr hard work .Last edited by Genem; 09-29-2014, 06:40.
Originally posted by dave220 View PostI am having a problem installing 2.0 on my system. I never had such problem thus far. Everytime has worked on the previous updates. I tried method, 1,2 and 4. None of them work. It goes to recovery and then installs and then when it reboots it goes to a black screen. Nothing happens. It does not boot.
Anyone seen this ?Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
hey.
I did not try that. The earlier updates did not need that. Ok I will try that and let you know.
Originally posted by ant View PostHey dave, did you try ejecting the sdcard before rebooting? or maybe you got a bad download of the ROM if no method will work?Using a Tronsmart Vega Elite S89.
Xmbc versions seem have various issues with certain setting.
1080p or 720p can totally through it for a loop and some versions behave better then others depending on the setup.
Its the biggest failing of xmbc i think that requires a very narrow environment to work perfectly.
Fortunately with so many modding it there are many versions you can try to dins one that works.
Spmc seems to play nice with this rom .Mk802IV Neomode 1.9a original rom 720p
Originally posted by Genem View Postistalled this one over 1.08.without problems. no need anymore to adjust screen to 91%. 100% is now perfect.
helix is crashing all the time so I use SPMC. on 1080p 60hz, no more drops or skipped frames. im happy now. thanks finless for yr hard work.Originally posted by dave_999 View PostThumbs up with SPMC! Smooth as silk.
There are currently 2512 users online. 2 members and 2510 guests.
