About the same stuff I do to my ROMs but this time I did not have to do everything as Oman is now putting much of my patches in the stock ROM!
But not everything as you can see below.
____________________________________
This is based on the S82/S89 109K4 ROM.
This is for the following devices:
- Tronsmart S89 and S89-H
- Beelink S82 and S82-H
- Beelink M8 (black and red round box)
- Beelink MXIII 2GB
This IS NOT for the ENY/Acemax EM8 square box!!!
Features and release notes for my 2.0 ROM:
1) 109K4 was now rooted from the factory! So I did not need to root it this time
2) Updated Google framework core files. The ones in the stock ROM were out of date.
On first boot NOTHING will need to be updated once you logon to Google Play.
That is as of this date.
3) Debloated of junk APPs and Google Apps you can get from Google Play.
There was quite a few useless hidden apps in this KitKat release! Some of them did not even work.
I did remove XBMC and other pre-install APPs as well. I like a CLEAN ROM that you the user can setup the way you want. Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer).
NOTE: The XBMC that came with 109K4 is in this ZIP package (Oman modified). Feel free to install it if you like.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
This time around due to updated security in 4.4, init.d was a lot harder to get working.
Again I had to figure it out!
5) I fixed the AOSP Launcher for several things:
Removed the Google search bar by request.
Added more than one screen for scrolling.
Updated the dock icons to things more useful.
Apps installed with Google Play will automatically be added to the home screen.
I think you will like this launcher better
6) Calendar and Contacts sync is now fixed by Oman so I did not have to fix it this time. THANKS!
7) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
This should also allow Netflix HD but I have not tested it.
Your device will show up in google play as Nexus 10 device not a S82/S89! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a S82/S89.
8) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
9) Adjusted some permissions so stock XBMC works (but not 4K and I didn't test all audio output capability).
I did install Kodi and it works for me and I did not see any sync issues. But again I did not test everything.
10) Added bonus! CPU fixer patches!
In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor. See the README.txt in that folder for an explanation and how to install them.
11) Sorry folks. 720P patcher will not be provided this time!
Why? Because the code has now drastically changed and I have not been able to make it work this time.
I will continue to try and get the 720P patch working again.
12) Carrier spoofs for better APP compatibility.
13) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
14) Did a little "themeing" to the AOSP Launcher stock wallpaper.
________________________________________________
DO NOT just copy this download ZIP to SDcard and expect it to work!
UNZIP it and read the README for instructions!
OK so here is the download!
READ the README.TXT in the zip for instructions!
ROM -> Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless ROM 2.0 (419 megs)
