Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Originally posted by dankec View PostI'm still on AMLinux, but now I'm considering Finless 2.0...
Most of the time I'm using XBMC/KODI... Few things is not clear here:
1. How good android XBMC works with streaming add-ons (Mashup, 1channel, simple player, genesis...)?
(My only reason to go to linux distro was "Adjust display refresh rate to match video" which is, unfortunately, not available under android. Even with that option on XBMC is still stuttering under AMLinux)
2. If I decided to migrate to android... should I use Kodi 14 beta 3 or SPMC?
3. If SPMC, could someone, please, post SPMC download link?
Thanks.
Originally posted by bajann View Postminix make addon in xbmc to display refres rate to mach video but only for minix x8RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostBut as I know only to change it manually at XBMC instead at Settings , no auto...
i hope this will work on all amlogic device
Originally posted by Veronica View PostCozyswan MK809II - 4.4.2
Vega S89 Elite - 4.4.4
Originally posted by Gaili View PostNope tried it doesn`t work > bootloop, reinstalled 2.0 Kernel
Originally posted by Veronica View Postdo you know what helps?, placing the box in vertical position. Since i did that easy move my box does not get very hot as it used to in flat position (the small holes at the bottom of the box were useless in that position and the box would not "breath" properly, dus overheating the box and the table material under it).
Originally posted by bajann View PostWhy not biger heatsink ?
What i mentioned is very simple and quick to do and does help, i dont think i need to drill holes to it. Running the 1992Mhz cpu fix
Originally posted by Veronica View Postthats more advanced and not easy to fit a heatsink into that case and hold it right, unless you don't mind destroying the plastic case.
http://www.freaktab.com/showthread.php?13421-AML-S802-case-modding-Show-your-mod-s-to-cool-it-down-%29
Mk802IV Neomode 1.9a original rom 720p
Originally posted by no_spam_for_me View PostBut as I know only to change it manually at XBMC instead at Settings , no auto...Originally posted by bajann View Post
how to tell, how can i know if it works or not?
I set it to: On Start/Stop and -Pause during refresh rate change is set to OFF
I may not have good eye but all videos play just fine to me but im curious if there is an advantage
but you are wrong, because I don't own any minix device any longer
I think it isn't really difficult to port it to every other system you want.
The importend parts at the "fswitch_util.py"
Code:modeFileAndroid = "/sys/class/display/mode" modeFileWindows = "d:\\x8mode.txt" if fsconfig.osPlatform == 'MINIX NEO-X8': modeFile = modeFileAndroid elif fsconfig.osPlatform == 'Windows 7': modeFile = modeFileWindows else: outputMode = 'Unsupported platform.' return outputMode, amlogicMode : # convert output mode to a valid AMLOGIC mode if newOutputMode == '1080p-60hz': newAmlogicMode = '1080p' elif newOutputMode == '1080p-50hz': newAmlogicMode = '1080p50hz' : : # set new display mode with open(modeFile, 'w') as modeFileHandle: modeFileHandle.write(newAmlogicMode) :
2.) osPlatform must be change (maybe also at other *.py)...
3.) and maybe newAmlogicMode to something like newDisplayMode and also the values...
Seams to work also at Windows 7, but don't ask me why he implemented it, maybe for testing?RK3288 Devices
Originally posted by Veronica View PostI do see that option on SPMC as well as on other xbmc versions for our boxes but i guess is broken anyways?
and that isn't available at android...RK3288 Devices
Originally posted by no_spam_for_me View PostI thing you talk about auto frame rate switching at settings
There are currently 2275 users online. 3 members and 2272 guests.
