add it there, describe the problem better.
Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Great work bob ... I have the 2.0 finless and put xbmc kodi the one u posted I had video problems where the picture was disoriented fixed it with going to setting mbox switching the video detect to 1080 rather then 720 which it detected ... so far so good on kodi .... as for my wonderful bell app no go on these fixes will wait for more releases
Re: NEW - Beelink S82/S82H/M8 & Tronsmart S89/S89H - Finless 2.0 ROM
Originally posted by londonshore View PostGreat work bob ... I have the 2.0 finless and put xbmc kodi the one u posted I had video problems where the picture was disoriented fixed it with going to setting mbox switching the video detect to 1080 rather then 720 which it detected ... so far so good on kodi .... as for my wonderful bell app no go on these fixes will wait for more releases
Originally posted by Finless View PostI have no crashes with Kodi and Superuser.
I watched about 5 movies straight last night and not one crash.
I think your box has some problem.
wow i would of fallen asleep after half way of movie and the mrs would been telling me to go to bed because on my snoring hahaha
JustMeBugs are Sons of Glitches!
JustMe
IOriginally posted by Veronica View Postdo you know what helps?, placing the box in vertical position. Since i did that easy move my box does not get very hot as it used to in flat position (the small holes at the bottom of the box were useless in that position and the box would not "breath" properly, dus overheating the box and the table material under it).
4 months ago i did some mods with my M82 ... check out the pictures. I replaced the original heatsink with a segment from a old videocard, polished the bottom and put Arctic Silver 5 paste on it. I also drilled some holes in the bottom and 1 big hole in the top cover for air circulation and i changed the internal antenna to a external one with now 20dbm more signal. Anyway the problem with the m82 is, that all boxes with 5 degree steps are thermal calculated, that means this is not the real cpu temperature.
You can find that in the dmesg log, it looks like that:
amlogic_thermal_probe, this chip is not trimmed, use virtual thermal
aml_virtaul_thermal_probe, virtual thermal enabled
Use "virtual thermal control" means, that you can put your box in a freezer, it changes nothing! We need a kernel mod to lower the calculated temperature.
GreetsLast edited by Gaili; 30 September 2014, 10:13.
Originally posted by isham.padron View PostI was really hoping that this update would fix the Wifi+bluetooth issue. For context its really hard to stream music to my motostream via bluetooth through google music or youtube. I understand that it might be freq. problem but I have no problem streaming using my iphone 4 or my Nexus4
Originally posted by Veronica View PostI do see that option on SPMC as well as on other xbmc versions for our boxes but i guess is broken anyways?
how to tell, how can i know if it works or not?
Originally posted by Veronica View PostThe same menus i see in Android, as i said it b4 may be broken anyways. Don't know
Originally posted by dankec View PostIt's very easy to check: install Stane's AMLogic firmware where it works great! Anyway, TV resolution changes to movie native as soon as you click on play. When you click on stop resolution returns to XBMC system default.RK3288 Devices
- Overview BOX (LINK !)
M82 - Does not wake up from hibernation
Hi there!
I've recently installed, and then installed again the 2.0 version, because when I put the device to hibernation, sometimes I can't wake it up with the remote controller. The led turns blue, but the device does not boot, and I have to hold the power key to turn it off completely. Any solution for that (besides going back to 1.9)?
Kind regards,
Kind regards,
I'm on Finless 1.7 right now.
There are currently 2482 users online. 1 members and 2481 guests.
