Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.0 ROM
Fricking fantastic Bob gotham 14 beta 3 working spmc working. Picture awesome. For all those crashing in gotham beta 3. I Uninstalled it on one box re booted then re installed and re booted once again after first set up it ran fine after that don't ask me why just worked.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by chsmith1976 View PostI didn't know there was a TWRP recovery for the S89. Could you kindly provide a download link?
I dont like the desktop wallpaper in this version, I'll have to revert back to v1.9
Just kidding
Alls good so far. I was able to load in my xbmc data backups, change wallpaper without issue .
Thanks Bob
Noob question. How do i get the browser to allow saving my bookmarks to google instead of 'local'?Last edited by Joffa; 07 October 2014, 08:18.
Originally posted by Veronica View PostThat's good news, apparently there was few issues with SPMC before for our amlogic boxes, i'll give it a try. BTW do you ave all 3 codecs selected or only Amcodec?Last edited by Genem; 29 September 2014, 06:43.
I'm still on AMLinux, but now I'm considering Finless 2.0...
Most of the time I'm using XBMC/KODI... Few things is not clear here:
1. How good android XBMC works with streaming add-ons (Mashup, 1channel, simple player, genesis...)?
(My only reason to go to linux distro was "Adjust display refresh rate to match video" which is, unfortunately, not available under android. Even with that option on XBMC is still stuttering under AMLinux)
2. If I decided to migrate to android... should I use Kodi 14 beta 3 or SPMC?
3. If SPMC, could someone, please, post SPMC download link?
Thanks.
Originally posted by dankec View Post2. If I decided to migrate to android... should I use Kodi 14 beta 3 or SPMC?
Thanks.
Originally posted by Genem View PostIf I were you, I should try SPMC (can be found in the playstore). Disable AMlogics code in HW and there will be no more hick-ups. At least in my situation.
Tempature Problem
Hi Bob,
i have one of the temperature calculated M82 Boxes, means the one with the old Cpu and the 5 degree steps. Since i installed the version 2.0 of your rom, the temperature stays between 70 and 80 degrees with nothing running on it. I do not use the cpufix. That is 25 degree higher than with your 1.9 rom when the the box is in idle. Actually i also tried oman 109k4 same problem there ... ist there a pach which i can use?
thanks
Only thing you might try is 109 kernel.
Use my CPU fix Stock from 1.9 ROM. This will install 109 kernel.
There are currently 1525 users online. 0 members and 1525 guests.
