U65GT_V1.8.4_20140930W_en_mod_Lepi
    lepi a question.
    did you posted before few days a customise v2 rom for cube 9x?
      Originally posted by epsa View Post
      lepi a question.
      Don`t understand. This post? Or questions about other?
      videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
      TWRP_2.8.1.0
      TWRP_2810_newTheme TWRP_2.8.5.0
      PayPal donate WMID410517421626
        AW: U65GT_V1.8.4_20140930W_en_mod_Lepi
        Originally posted by Lepi View Post
        Hi, everyone. I publish updated to version 1.8.6 white Theme.
        Thank you very much for publishing. This is the perfect version for the Cube tab.
          Hi, everyone. I publish updated to version 1.8.6 white Theme. The changes affected the interface. Now it is fully light.
          upd_U65GT_186W_en_Lepi.zip
          Install only on version 1.8.5 white!
          Installation Instructions:
          Only for installation through modrecovery CWM or TWRP!
          Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card.
          Wipes do not need.
          Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
          There are no guarantees! Risk and assumes responsibility fully by the user.
          Preliminary backup is required!
          Successful upgrade!
          Thank you for the work you do. Y-will he UPDATE U65GT_186B_en_Lepi for the black version 1.8.5 which obviously is in English? Tell me if francophones can install it.
            Yes, it is multilanguage.
            TWRP_2.8.1.0
              Hi, everyone. I publish updated to version 1.8.6 white Theme.....
              Don't want to interfere in your update pleasure, but I think you'll have to flash Lepi's white version 1.8.5 FW first.
              @Lepi, if I misunderstood, feel free to comment.
              Regards, Edy.
                Regards, Edy.
                That's right, thank you.
                *Install only on version 1.8.5 white!*
                TWRP_2.8.1.0
                  Thank you for your answers but I would like to know if there will be a similar update for the black version.
                    Thanks for The update 1.8.6! All works perfect. Only one thing :
                    Statusbar is buggy.
                      Statusbar is buggy.
                      It's not a glitch. This is a feature.
                      TWRP_2.8.1.0
                        Really?
                          TWRP 2.8.2.0
                          Hello Lepi,
                          are you planning an updated release of white TWRP for version 2.8.2.0?
                            Originally posted by tempdroid View Post
                            Hello Lepi,
                            What's new?
                            UPD
                            I find:
                            -Pull in all changes from Android 5.0 lollipop into TWRP
                            -Add decrypt support for Android 5.0 lollipop encrypted partitions including automatic decrypt when the default_password is in use
                            -Revert some changes to exFAT that were breaking exFAT support on some devices
                            -Other minor fixes and updates
                            TWRP_2.8.1.0
                              What's new?
                              I was a bit too fast. It seems only to be available for the Nexus 9.
                              This is the changelog:
                              Have a nice day anyway
                                TWRP 2.8.1
                                Hi Lepi. First of all thank you very much for your development and help. You did a great job ;-)
                                I tried your Recovery TWRP_2810_light_LEPI+newTheme.zip, it looks pretty nice and I love also screenshot possibility, but its not working very well :-/. I cannot wipe anything (especially dalvik), the recovery log give many errors and freeze - see attached screenshot.
