Q7 bricked?
Originally posted by Kooiboy View PostHi songsoveredoke i have to do the pin trick. Can you tell me what pin
I take it you need to do this because you are having problems erasing the IDB ? If so, have you tried erasing with Androidtool v2.1? (This is "ROM_Dumper_Tool.exe" which comes with rk_tool21_how_to.zip ) . The EraseFlash function under the "Upgrade Firmware" tab seems to erase the IDB differently, in a way sending it straight to Mask Rom mode. I'm wondering if you try this you may not need to short the pins.
Originally posted by nevoz View Post... I'm relatively sure it's pins 8 and 9 ....
But it seems also no matter if you do so:
"Got it flashing again by using a paperclip on every nand pin until it entered mask rom mode." (can't remember where I find it)...RK3288 Devices
- Overview BOX (LINK !)
There are currently 2119 users online. 3 members and 2116 guests.
