I am using the latest beelink rom 110k4109
Both dolby digital and DTS are working, I'm using a marantz receiver.
Download and overwrite libmedia.so which is in /system/lib , I used esfileexplorer and set settings to enable root access. You can get the hacked libmedia.so from here;
Next download a custom xbmc that takes advantage of the libmedia.so hack. I used this Kodi release which you can get here;
In android settings/sound/sound devices manager ensure it is set to HDMI Bitstream.
In xbmc set the audio output to 2.0 (setting to 5.1 causes lag on sd streams)
Enable passthrough checked.
Enable dolby digital transcoding is checked.
I restarted the whole system just to make sure, many thanks to Wasser for the hacked libmedia.so for kitkat and also Karel for the Kodi release to take advantage of libmedia.so.
Hopefully it will also work for you, if so maybe the changes in libmedia and also the modded xbmc could be merged with current software?
