Working HDMI passthrough.
Originally posted by mo123 View PostMaybe someone can upload Beelink Finless ROM 1.2 libmedia.so file so it can also be patched and see if it also crashes like the libmedia file in post #66 ?
I agree with mo123, if you have a problem upload you original libmedia.so file and I will take a look at it.
Originally posted by Aicgod View PostAnyone else experiance a complete rom reboot (Finless) when trying to play an Youtube SD video in XBMC/SPMC. Everytime I select an stream with youtube SD as the source it re-boots the Rom as soon as it tries to open the stream. I experience it in the Youtube plug-in and Genisis. The Youtube app runs fine. Running patched libmedia.soMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostY
Because of this echo effect, I use the modded Kodi instead of SPMC 13.3.3.
No problems with SPMC and youtube (Stafstrom's libmedia.so, Finless 1.2)
Originally posted by 4WheelSpyder View PostIn my case SPMC 13.3.3 has very stuttered audio(passthrough enabled), even the surround sound indicators on the receiver are flashing. Modded Kodi is pretty much what it was before, still crashes when I try to advance the movie.
No problems with SPMC and youtube (Stafstrom's libmedia.so, Finless 1.2)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by 4WheelSpyder View PostWhat do you use to advance? I am using either the slider or the left arrow on the IR remote - both cause it to crash.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Just got an update from the play store for SPMC. I know Koying was working on our echo problem, but this update crashes, and the echo problem is still there. I tried disabling the hardware codecs in the settings, but that did not help.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Aicgod View Post[ATTACH]8582[/ATTACH]
Here is the original libmedio.so from finless' rom 1.2 for Beelink
I have patched your version, hopefully this will solve your problem.
First, I want to thank Stafstrom, Koying and Jakemate for getting Dolby passthrough from XBMC and SPMC. I just installed Stafstrom's libmedia file on my R89 and rebooted. Same thing happened, audio echo and crashing. I cleared the data then uninstalled SPMC and rebooted. Downloaded SPMC from play store, added videos from my Synology NAS. Everything is working perfectly now. I can change to DTS, no crash. I can can use the on screen fast forward arrow, even with 3 clicks, for faster forwarding, still did not crash. I can say that on my end, SPMC is perfect.
Thanks again
Edit: after stopping and restarting SPMC the echo is back. I start with Dolby which has an echo then switch to DTS that does not have the echo, then back to Dolby and no echo. Strange.Last edited by clarkss12; 31 October 2014, 00:29.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostFirst, I want to thank Stafstrom, Koying and Jakemate for getting Dolby passthrough from XBMC and SPMC. I just installed Stafstrom's libmedia file on my R89 and rebooted. Same thing happened, audio echo and crashing. I cleared the data then uninstalled SPMC and rebooted. Downloaded SPMC from play store, added videos from my Synology NAS. Everything is working perfectly now. I can change to DTS, no crash. I can can use the on screen fast forward arrow, even with 3 clicks, for faster forwarding, still did not crash. I can say that on my end, SPMC is perfect.
Thanks again
Modded XBMC is fine but SPMC would stutter the audio with the surround sound indicators flashing regardless of the type of surround sound encoding, whether it is passed through or transcoded. Even tried a re-installation of SPMC - same results.
There are currently 3016 users online. 1 members and 3015 guests.
