Working HDMI passthrough.
Originally posted by no_spam_for_me View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Tried it on my R28 last night with Bob's ROM.
Whenever I attempted to replace the existing libmedia.so file the box would reboot.
I had to delete the existing version first.
I didn't work for me though when I did apply it but as I mainly use SPDIF it isn't a big issue for me.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by 4WheelSpyder View PostTried it with the latest Kodi nightly. Does not crash but although the passthrough works, the video still has the jump every couple of seconds. I only tested it the short helicopter dogfight video that oman provided which is maybe why I dont see the crash?.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hmmm, different outcomes it seems.
Is everyone using the same rom?
Might be worth a fresh install of beelinks 110k version and testing the stock xbmc, I'm thinking if people are on different roms or have installed many different xbmc's on their unit then redundant or differing files might play a part in the differing results.
Just a thought?
Originally posted by clarkss12 View PostSo you verified that this libmedia.so does NOT require a special version of XBMC?
Kodi runs but it has the same symptoms that it had with the HDMI patch on the 109k4 software.
SPMC, I get video (but in semi slow motion) and no sound - the surround sound indicator on my Yamaha receiver flashes with both spidf and HDMI pass through settings - first time that I have seen this. The "enable transcoding" setting does not make a difference here.
I am running Finless 1.2 ROM with the modded libmedia.so file
Correction: The "enable transcoding" setting actual does make a difference. The surround sound indicator flashes when the transcoding is enabled. Looks like the disabling did not take into effect when I tested it the first time aroundLast edited by 4WheelSpyder; 23 October 2014, 21:51.
Runing Finless 1.2 on Beelink R89. With "special Kodi", playing a video working until I step forward 3 or 4 times, then it crashes to the desktop. Trying to switch to DTS causes it to crash immediately. This is very consistent. Now I am going to uninstall the "special Kodi" again and see what happens.
BTW, the videos play very well.
With Kodi uninstalled and only SPMC on my box, I still have Dolby passthrough via HDMI. It did NOT crash when stepping forward, I could also change to DTS and it played. However, there is a slight echo which I have never experienced before.
Now I will install the latest Kodi and test it.
Edit 2: installed latest nightly Kodi (October 19) , no surround. Rebooted box, still no Dolby. Tried SPMC again, still have Dolby and DTS. Very strange.
Edit 3: reinstalled the special Kodi, still crashes when switching to DTS, and stepping forward. Other than those 2 items, it plays well with Dolby passthrough.Last edited by clarkss12; 23 October 2014, 23:22.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Modded Kodi and lib file combo works for me!
Got the modded "special" Kodi to download to my PC. Chrome again had some warnings and renamed the zip file. So I copied it to an SD card, restored the file name, unzipped it in the R89 and installed it.
Finally a R89 that can play Video files with 5.1 AAC Surround Sound without a stutter every 2 seconds! HD DTS works as well.
Re: Working HDMI passthrough.
Originally posted by 4WheelSpyder View PostGot the modded Kodi to download to my PC. Chrome again had some warnings and renamed the zip file. So I copied it to an SD card, restored the file name, unzipped it in the R89 and installed it.
Finally a R89 that can play Video files with 5.1 AAC Surround Sound without a stutter every 2 seconds! HD DTS works as well.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostEdit 3: reinstalled the special Kodi, still crashes when switching to DTS, and stepping forward. Other than those 2 items, it plays well with Dolby passthrough.Almost there.
Yes I can confirm mines the same, crashes on forwarding etc.
But at leat theres some continuity here and the hdmi passthrough works. Now just got to figure out why xbmc crashes on forwarding etc.
Im no expert but would changing the advancedsettings.xml alter anything?
I may try tinkering again tomorrow as its late here and im off bed
Originally posted by 4WheelSpyder View PostYes, I can confirm the same problem when stepping forward - crashes to the launcher screen. Any method of advancing to a point other than the start will result in a crash.Almost there.
I have one file with both AC3 5.1 and DTS 5.1 audio. Playing the AC3 5.1 audio is fine. As soon as I select the DTS audio source the R89 box immediately crashes as per clarkss12 finding.
I think this has to do with the modded libmedia file since MXPlayer also crashes when I select the DTS audio channel.
Originally posted by 4WheelSpyder View PostI have one file with both AC3 5.1 and DTS 5.1 audio. Playing the AC3 5.1 audio is fine. As soon as I select the DTS audio source the R89 box immediately crashes as per clarkss12 finding.
I think this has to do with the modded libmedia file since MXPlayer also crashes when I select the DTS audio channel.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3015 users online. 1 members and 3014 guests.
