CAREFUL! My downloaded file was over 800kB (instead of the expected 560kB) and changed to an .exe. The virus checker wanted to delete it.
Working HDMI passthrough.
Originally posted by Finless View PostHow do you use this place? I cannot see how to download only download downloader apps and junk.
Then you can choose from 10 different filehosts to download.
I use a popup blocker and add-blocker in chrome, so never noticed there were popups.
But here is a Mediafire link for libmedia.so for people having trouble.
Seems other people already posted a different link before I posted, thanks.
Thanks for the original libmedia file jakemate and mo123.
I have created a patched version but I can't guarantee it will work. This version was very different from the ones I've seen before and because I haven't worked with arm assembler in a while there's a chance I messed up.
The only way to know is if someone is prepared to test it.
I have patched the file with my improved version of the hack, that should fix reported sound problems with some VoIP apps caused by my original hack.
Originally posted by stafstrom View PostThanks for the original libmedia file jakemate and mo123.
Thanks for your help.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostYes, Stafstrom, your version is working very well. My XBMC and SPMC no longer crash when changing from Dolby to DTS. I do have a problem with SPMC but not XBMC (Kodi) where the Dolby audio has an echo. This happened with the libmedia.so that Jakemate created also. This is the first time I have ever experienced this problem.
PS From my side also thanks to Staftrom for looking into thisLast edited by 4WheelSpyder; 10-28-2014, 03:03.
Originally posted by 4WheelSpyder View PostWhich installation of XBMC are you running Clarkss12? The modded version?
PS From my side also thanks to Staftrom for looking into thisMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by mo123 View PostAnyone tested with SPMC 13.3.3?
Can't remember, but think device needs to be rk3*** in build.prop.
Can someone test?
Because of this echo effect, I use the modded Kodi instead of SPMC 13.3.3.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
youtube crash
Anyone else experiance a complete rom reboot (Finless) when trying to play an Youtube SD video in XBMC/SPMC. Everytime I select an stream with youtube SD as the source it re-boots the Rom as soon as it tries to open the stream. I experience it in the Youtube plug-in and Genisis. The Youtube app runs fine. Running patched libmedia.so
Originally posted by Aicgod View PostAnyone else experiance a complete rom reboot (Finless) when trying to play an Youtube SD video in XBMC/SPMC. Everytime I select an stream with youtube SD as the source it re-boots the Rom as soon as it tries to open the stream. I experience it in the Youtube plug-in and Genisis. The Youtube app runs fine. Running patched libmedia.so
Are you using the correct libmedia.so for your device?
If using RK3288, use a ROM after 20141011 and libmedia.so from #66
The opening post is for RK3188 devices.
There are currently 2074 users online. 4 members and 2070 guests.
