HPH RK3288 ROM v1.2 by mo123 (20141117)
    New ROM v1.4 Released - 01/01/2015
    Changelog from v1.3 ROM
    Audio: fix bitstream pause/seek maybe noisy or no sound
    Android->Camera:Adjust the OV13850 direction
    Audio: kernel: add support for lossless audio
    Audio: update hal for direct
    Not sure of other changes, based on latest 30-12-2014 firmware
    SPDIF passthrough now works in SPMC
    Latest SPMC included
    1080p Youtube
    Wifi tweaks
    Full left over device space used for Apps
    Solo Launcher, now with Material design theme
    De-bloated stock Apps, only minimum apps included
    Boots fast
    For people that flashed v1.3 ROM(Android Only) you can probably re-flash
    boot, kernel & system only, but not tested.
    If you want all apps included it's better to stay on v1.3 ROM
    Only use this if you want a clean ROM or working SPDIF passthrough.
    To root the ROM type the following in the calculator app
    !^06^
    UPDATED - 01/01/2015
    Link: Here
    HPH RK3288 2014/11/17 ROM v1.2 by mo123
    Changelog v1.2
    Based on 2014/11/12 v1.3.35 ROM
    Code:
    - Update new librk_on2
    [B]- Blu-ray : support 3d ui
    [B]- Surface: fixed the bug that screen piture is black color when screen capture[/B]
    - U-boot: bootloader(v2.17.02) updated
    - NAND DRIVER: Fix reboot in nand driver issue
     - Rga/rga2 driver error handling fixed
    - Updated loader
    - Update uboot from rk_develop_box
    [B]- Fix some 4k h.265 crash[/B]
    [B]- Update ffmpeg[/B]
    - RK: ion: add event tracer
     - RK3288 hdmi: modify 74.25MHz pll config.
     - Mmc: workaround  DDR mmc devices internal divider bug
    [B]- Disk: to support the ext4 file system[/B] u-disklog:remove the invalid printk
    - DDR : do not set the frequency when ddr initialization
     - USB: fix handle NAK for IN/OUT SSPLIT/CSPLIT transfers
    - HDMI&FB : Temporary do not automatically switch fb  when HDMI plugging
    [B]- wifi->ap6335 - Update the firmware, strengthen the new module compatibility[/B]
    - Ethernet:gmac: fix the bug of connection failure with PHY because of wrong phy_addr
    - Fix app install-external error when app2sd is not supported
    - Pppoe:fix the bug of no upstream for hotspot when pppoe is connected
    [B]- Update Camera driver[/B]
    [B]- Update videoplayer.apk for some problem[/B]
    Overclocked CPU to 1.8Ghz
    4GB Userdata for Apps by default
    Latest Google Apps
    Removed 15 Bloatware apps
    SPMC v13.3.4(Perfect video playback)
    [/B]- Can seek forward/backwards without any crashes
    - Videos play more smoothly
    - Most video formats play correctly, in Kodi Beta 1/2 some avc/mkv files only show black screen, they play correctly
    - Passthrough support(some receivers might still have hissing sound, only way to fix that is using unstable Kodi beta 1 PT or wait for final Kodi Helix)
    Fixed playback issues as in previous ROM version
    Solo Launcher(Replaces Nova Launcher)
    - App Drawer Groups
    - App Drawer Folders
    - Nice and fast
    - Developer will add more columns in homescreen in next version for TV Boxes.
    Exposed Modules
    - Youtube Adaway
    - Fake Wifi(Enable to run apps/games that require a wifi connection to run)
    - Transparent status bar
    - Fake ID + 3 other security fixes
    Rootcloak -
    Hide root from apps
    HDMI Virtual Switch -
    Hide HDMI status from streaming apps
    AdfreeTime -
    For DNS server, Sign-up here
    DNS Forwarder -
    To enable DNS server on KitKat for AdfreeTime
    Wifi tweaks
    as in previous version of ROM
    Passthrough
    support with SPMC or Kodi Beta 1 PT app
    Changelog v1.0
    Based on 20141021, v1.3.9 ROM
    Code:
    - [B]Long pressing the menu button can show/hide the status bar.
    - Delay 1 second for Shutter effective time, solved the problem of green screen
    - Solved the problem of YOUTUBE video quality unable to display 1080P setting.
    - Added service flash_recovery2 /system/etc/install-recovery-2.sh, in   order to be compatible with the YYF script, focus on YYF APK issue of   chinese version, download and install is ok directly after root.
    - Modify the remote control response, and the hidden the button of edit   picture, please open the picture compiled from menu actionbar
    - IR remote control indicator using the LED trigger control, modify timer delay
    - Press the key of common use for a few seconds to switch the mode of mouse
    - Added airplay
    - Solved the bug of SOC Camera that could not open, the reason is that the CameraHal and Driver versions does not match.
    - Solved part of the YUV Camera preview screen flash problem.
    - Updated Blueray support for RKVideoplayer.
    - Updated RKVideoplayer and fix some error.
    - Update the hdmi output format in 4k@60hz
    - Fix edid 3d format parse error
    - Updated ffmpeg codecs[/B]
    Extra Mods
    - XBMC is replaced by SPMC 13.3.3(ROM v1.2 replaced this)
    Enable Mediacodec and disable Libstagefright in SPMC Settings for best playback.
    Green artifact bug on some videos is fixed.
    4K videos now play full speed again without dropped frames.
    - YouTube
    Can play 1080p quality now
    YouTube ad-blocker included, install exposed module, activate YouTube module and reboot your device. Might not always work immediately when YouTube gets updated.
    - Launcher
    - Can choose between default & Nova Launcher(ROM v1.2 replaced this)
    - ROM is rooted(Thanks to Bob's method)
    - Device spoofed as Samsung Galaxy for improved compatibility(Removed in v1.2)
    - Fixed problem with certain cable apps not working, yesGO, Comcast & Xfinity, drm satellite cable apps that have issues with DRM (solution found by bluesmanuk)
    - Improved wifi performance and buffering
    - Included Netflix, Hulu, Youtube, SPMC, TuneIn Radio, Terminal app, ES File Manager, Dolphin Browser, BBC IPlayer, MXPlayer & Ad-Away. Reboot by Petrus
    - Most apps updated to latest version, maybe 1 or 2 Google apps still update after boot.
    - Extra remote files for Mele F10 & other Airmouse etc.
    To access 'Developer Options', Click 5 times on 'About Device' in Android Settings.
    (Drawer Tabs)
    Homescreen - Yours will look different with other wallpaper & theme
    (This theme is included if you want to enable it, another theme, Android L is also good)
    New Bootanimation
    Download link
    Old: HPH RK3288 v1.0 2014/10/26 Here or Here
    New: HPH RK3288 v1.2 2014/11/17 Here or Here
    Update: 2GB Parameter file for 8GB Box Here & 8GB Parameter file for 16/32GB Boxes Here
    Instructions
    Connect OTG cable to box and PC.
    Hold paperclip/toothpick into reset hole while connecting the power to box.
    It should now connect. If not reinstall the drivers and try again.
    1. Unzip with 7z
    2. Use the first tab of AndroidTool v2.3 to select the Images to flash from the ROM.
    (Already set-up by default)
    Default is 4GB Userdata, but can be replaced with updated above parameter files.
    3. Click 'LowerFormat'
    4. Click 'Run' to flash the ROM
    5. Wait 5 minutes
    6. Unplug device from PC.
    7. Connect to display.
    Don't mix with other ROMS since this ROM has different system.img and latest bootloader in boot.img. Can use resource.img and boot.img from another ROM if it was released in November but not needed in most cases.
    PS: Only use default parameter file - rk3288-3.10-uboot.parameter, it is 4GB. Other parameter files will brick your device. See above for updated 2GB & 8GB parameter files.
    Solo Launcher
    (How to setup App Drawer Groups and Desktop Layout)
    1. Copy the backup directory to /SDCard/SoloLauncher
    2. Go to Solo Launcher Settings - Click Restore Solo Settings & Desktop Backup
    Restore the backups shown
    Other
    1. Download latest AdAway lists
    2. Download Xposed framework and enable modules.
    3. Update SU binary
    HPH/Ugoos IR Remote
    - Long Press Menu button to Hide Status Bar
    - Long Press Recent App button to turn direction keys into mouse mode
    - Long Press Power button to turn off, Short press for standby.
    Any suggestions, improvements or bugs, please share, so I can fix it or report it.
    There is a limitation to only have 800MB for system.img on Windows.
    Also no CWM for RK3288 exists, otherwise it would have been easier to include more apps.
    For AC3/DTS PT in Stock Video Player
    1. Copy libffmpeg.so, librkffplayer.so & patchedlibmedia.so to system/lib
    2. Restart device
    3. Works in Stock Video Player and Kodi Beta 1 PT patched
    Automatic framerate in HPH SPMC
    Please test improved SPMC Auto_Frame_Rate_Switcher on your HPH devices.
    Unzip and install as addon from zip.
    Go to Program addons to define the shortcut keys and enable the service. Restart SPMC afterwards.
    Press your short-cut keys to change to 24/50/60hz or automatic.
    45
    Apps
    6.67%
    3
    XBMC Playback
    20.00%
    9
    Launcher
    11.11%
    5
    Tweaks(wifi, root, fake wifi, hide root etc)
    35.56%
    16
    Support
    26.67%
    12
    Good job! it seems awesome!
    Can i use it with r28 Tronsmart device?
      Hi seems great can I use it for HPH 4Gb / 32Gb
      thanks
        Yes, just split your latest Tronsmart firmware with the flash tool.
        Replace my boot.img, resource.img and kernel.img with your split firmware files.
        Then use mkUpdate.bat to make a single Image file to flash to your device.
        Try to use the latest 100k4 firmware of your device.
        I will try to upload boot.img for Tronsmart devices with my tweaks also.
          thanks
          Yes, because your have 32GB ROM, you can use a bigger user space partition.
          Maybe 8GB or 16GB parameter file.
          Just rename the bigger parameter file to the one in mkUpdate.bat, the default one without a GB size in it's name.
          Open the mkUpdate.bat file with notepad to see how it works.
            Logitech HD Pro Webcam C920, still not working
            Thank you for the link.
            I already upgraded my STB however I am still facing the same issue with my Camera.
            Logitech HD Pro Webcam C920 still not working with this firmware upgrade.
            Nik
              Nik
              Can you get a 'dmesg' in terminal app('su' then 'dmesg') and also a 'logcat' with catlog app in the Play Store.
              Also post the webcam's specifications and picture, website.
              Also a description of the problems you experience.
              Zip everything up, then I'll report the issue.
                Thank you for your support
                Please find attached the requested information
                Regards
                Niko
                  Regards
                  Niko
                  Have you tried other usb web camera apps from the Play Store?
                  Most probably the camera has to be enabled correctly in the kernel.
                  Just to make 100% sure, the camera was connected when you posted the logs?
                  See also here
                    See also here
                    http://forum.xda-developers.com/show...8#post47946858
                    Yes, the camera was connected when I posted the logs.
                    The only other apps that I am able to see this camera working are the followings:
                      Have reported your problem, maybe I'll get a response soon.
                        I actually use Bob 1.2 generic RK3288 firmware.
                        Can i use same RK tool flash with Bob 1.2 rom and replace with yours boot.img, ressource.img, kernel.img and just flash?
                        Thanks mo123 for support.
                          Hi mo123,
                          Because I have already installed last Friday 24th of Oct. the latest Nagrace firmware for the HPH 4Gb / 32 Gb box and I've spend some time to reinstall and reconfigure all the Apps that I had before and also all the Addons for XBMC and SPMC, from the backups that I did before upgrading again my box (already done it 4 times now), that I was wondering if I can flash your modded ROM that is based on the firmware that I have installed just by flash the images that you have tweaked without the need to start all over again. Is it possible? Which images should I flash only?
                          Thanks.
                            Originally posted by fmoreira66 View Post
                            Hi mo123,
                            Thanks.
                            You can flash boot.img for the wifi tweaks.
                            Can flash system.img for the
                            - remote files
                            - XBMC video payback fixes
                            - For the pre-installed apps
                            I'm not 100% sure, but the apps I mentioned in the OP will then be replaced eg. SPMC
                            There are addons for SPMC that you can install that make backups of all the Addons installed or manually backup the userdata folder of SPMC and restore it later, need to show hidden files and enable root access in ES File Manager to see files. Your other installed apps should stay the same, but I cannot guarantee it.
                            It will be best to flash ROM over again, but try to flash the 3 Image files first and see if it works.
                            The apps that get pre-installed from the system.img is the only thing that might give problems with your setup.
                            Hope it helps.
                              You can use my ROM and replace the boot.img, resource.img, kernel.img with the ones from Bob's ROM.
                              Might loose some wifi tweaks from the boot.img, but don't think it's very noticeable.
                              The system.img has lots of changes, so not 100% it will work correctly with Tronsmart Images, but it should. Try it, if it doesn't work, you can just flash Bob's ROM back again, very easy.
