HPH RK3288 ROM v1.2 by mo123 (20141117)
I'll open another Mediafire account and/or also use Google Drive.
Will use Solidfiles as a backup, since it supports remote file uploads.
Link added in the OP
Please provide suggestions for v1.2 of the ROM before I release it later this week
What launcher?
Theme?
Apps?
Anyone have experience with writing apps?
Still learning, will take a while.
Want to experiment with something.
Originally posted by mo123 View PostI'll open another Mediafire account and/or also use Google Drive.
What launcher?
Theme?
Apps?
i always load a speedtest by ookla.... and flash wont hurt....pinky
ES file explorer.
Petrus reboot 1.2.2/4
xposed installer with the vulnerabilities patched as identified by bluebox security scanner.
Whatever is considered to be the best version of XBMC with patch for hdmi passthrough applied.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Leanback launcher - Not available on KitKat, maybe still use Nova Launcher(Also has Android L theme)
Youtube for Google tv - Not updated anymore, normal Youtube works better
- es file explorer - Yes
- oakla speed test - Yes
- avast Antivirus - Yes, hope it doesn't slow down system
- kodi with libmedia hack - Yes, will replace SPMC
xposed installer with the vulnerabilities patched - Good idea
Will also make a clean ROM without apps.
There are currently 1731 users online. 0 members and 1731 guests.
