HPH RK3288 ROM v1.2 by mo123 (20141117)
Originally posted by m1pnk View Postmo,,,, how do i clear old rom when i do update..... switch is on first page and update is on second.....cant tie them together ?
I don't use switch, use paperclip in reset hole and then connect power to switch to 'flash mode'.
Maybe 'EraseFlash' on second tab and then 'Upgrade' if you flash single image.
Originally posted by The-Lord View Postwhen are you planning to use the Beta 1.3.26 for the ROM?
If nothing received by Friday, I'll make ROM with changes until 7/11/14 and some more of my own changes.
Originally posted by m1pnk View Postmo.... when i click erase it goes through op but fails on last thing.... then cant install firmware because no device found ?
Otherwise use the first tab again and flash single images.
Use the paperclip in the reset hole to force booting into 'flash mode'.
Originally posted by m1pnk View Postand in china they have done something mo.... im getting about 20mbps down with there one and about 55mbps with yours from a 150 input ?
so im stuck in the middle here.... yours keeps crashing... chinas dont crash but slow wifi ?.... how long is that new rom ?
What does wifi do if you flash stock China ROM and my boot.img? Maybe also check that.
Originally posted by hansxia View Postmediafire is awful for me, I can't get your rom and other roms from mediafire.
anyway, thany you mo123
Mediafire has resume support and very fast download speed.
Anyone know of another filehost with 10-20GB free space and lots of features except Mega where I can upload ROMS?
Originally posted by mo123 View PostYou can also use Jdownloader to download from Mediafire.
Originally posted by hansxia View PostTry https://www.solidfiles.com/, 50G storage, 500M file size.
Do you know if they support resumable uploads?
See files get deleted after 90 days, mediafire and firedrive(not working anymore) files don't get deleted. Also with 500mb limit, will have to split ROM's in 2 if they are bigger.
Other file hosts with folder, password protected folder, user access rights, one time links support etc.
Looking for a host with that features also, but free.
There are currently 2444 users online. 0 members and 2444 guests.
