HPH RK3288 ROM v1.2 by mo123 (20141117)
Originally posted by Shadi86 View PostCan you post the rom on the first thread or its already posted? I only see the older Rom for download, it make me confused
Download link:
New: HPH RK3288 v1.2 2014/11/17 Here or Here
EDIT: Too late. I see that you also found it.
Please provide feedback if you successful flash the ROM in your box because I have the same and yesterday although I try many times I could pass the grey boot man...
Originally posted by mo123 View PostAlso uploaded ROM to Solidfiles, filesize should be 489MB.
No need to substitute anything with files from 1.3.35 ROM, this is based on V1.3.35_141112 stock ROM.
Only use default parameter file - rk3288-3.10-uboot.parameter from v1.2 ROM. It is 4GB. Other parameter files will soft-brick your device since partition sizes are different.
ROM v1.2 flashed correctly to HPH 16GB & 32GB and should work without any modifications to Ugoos UT3.
If not working on Ugoos UT3, try these files.
http://www.mediafire.com/download/8x.../UT3_Files.rar
I am so sorry in advance to bother you.
but I really need help. Please, could someone help me?
my UGOOS is 4g/32G with the following firmware:
UT3_rooted_19.09.2014.img from ChinaGadgetsReviews.
This is one file of 450 MB.
So first, is this ROM suitable for the rest of the procedure ?
secondly, how do I use my own Resource.img and Boot.img during the flash of mo123 ROM ?
The SPMC playback is really good, no issues or crashes seeking in videos anymore and better 4K playback.
Remember to also restore Solo Launcher's 2 backups.
Solo Launcher is completely free and some of it's features are only available in paid Nova Launcher.
Can also release an SPMC addons update if interested. PM me the addons you want included, try to limit it to free, non-adware included addons.
Also want to make an app package but can't seem to find a working TWRP/CWM for RK3288 at the moment.
Very important to do a clean wipe, 'lowerformat' and use default parameter file, rk3288-3.10-uboot.parameter to avoid soft-bricking your device.
Originally posted by Hocine.Merouane View PostI am so sorry in advance to bother you.
Follow the instructions carefully.
If it doesn't work, look at #97. I uploaded the Ugoos boot.img and resource.img.
The HPH and Ugoos use the same hardware and firmware, so it shouldn't be an issue.
If you want to split your firmware
1. Open AndroidTool and go to 3rd tab, 'Advanced Function'
2. Then 'Firmware', Select your update.img file
3. Select 'Unpack' to unpack the firmware.
Sv: HPH RK3288 ROM v1.2 by mo123 (20141117)
Originally posted by fmoreira66 View PostIn the 1st post of mo123 you can find the download link for the latest ROM here:
Download link:
Help with Ubox R89
Hello Mo123,
I need help to understand this problem, I installed your new 1.2 rom to my ubox R89 sold by Tronfy all went well. while setting up my repos in spmc it report out of space. in android settings/storage it shows 3.81 gb free but Nand flash is full. is there any way to move apps to internal storage or a different format method to utilize my 8 gb of space. Can you help
Originally posted by Shadi86 View PostDo I need change anything when I flash your rom, I am on 2 firmware older right now and I have the 4g/32 box.. Sorry I have not read the whole thread
Wait 5 minutes after flashing finished for everything to be set up before unplugging from PC.
Works on 16/32GB Box and Beelink, Tronsmart and Ugoos devices also.
Wonderful !!!
it has finally worked !!!
thank you so much mo123 for your appreciated help and for being patient.
I have used the Boot.img and Resource.img from the unpacked ROM I referenced earlier (ChinaGadgetsReviews) dated 19.09.2014 and all the other files from your ROM.
I then followed the instructions from the 1st page (wait 5 minutes after the flash completes) and ta da !
Firmware seems stable. I use wired connection and it appears to be faster then with the original ROM (confirmed by SpeedTest).
The video and audio quality is much better with SPMC than with the other XBMC/Kodi versions I have tested before even on my Minix X8-H.
But not as good as the PCH A-410.
Picture is almost perfect!
Thank you ! Thank you !
PS: I have not used your Boot.img and Resource.img (.rar) posted in #97 as you stated they are too old.
I,m Rocking
Originally Posted by lemack
Hello Mo123,
You have to format and reflash the ROM but use this parameter file, it will give you extra space for an 8GB box. The ROM was actually made for 16/32GB boxes. But will now have more space for 8GB boxes also.
Many Thanks MO123.
Im rocking this box its awesome
There are currently 2110 users online. 0 members and 2110 guests.
