HPH RK3288 ROM v1.2 by mo123 (20141117)
    Hi, nice that there are still builders for custom ROMs of the RK3288.
    May I ask if there is hope to get DTS HD Passthrough?
    And even the small hope to get 3D Bluray ISO Support?
    Every else seems to run good on the ROM, when its not with XBMC.
    Thanks.
      Thanks.
      Final SPMC based on Kodi Helix Final will hopefully solve all those problems, but have to wait a few more weeks.
      Some Passthrough works on Kodi beta 3/nightly, just change Hardware Acceleration to Mediacodec, but forward seeking in videos don't work.
        R: HPH RK3288 ROM v1.2 by mo123 (20141117)
        But.. Does passthrough work with mxplayer ?
          Something strange I noticed with your ROM. When I hold down the power button on my air mouse to get the "power off" option and click on it, I can't power it back on with my air mouse. I need to use the original IR remote.
          My air mouse is this one:
          http://www.****.com/itm/NEW-Mini-2-4...item2a3e59fceb
            Try to install the custon DTS codec in MXPlayer's settings.
            Also use the patched libmedia.so file.
              The IR signal works differently than an Airmouse wifi signal.
              When the device is completely off, the IR maybe is still in standby to receive a signal but you need to have a booted up Android to load the airmouse driver which is then not available.
                Do not own yet the box. I always use custom codec for mx player and days works. But passthrough is another thing so I would like to know if it works with mx player in this box
                  ... But passthrough is another thing ...
                  Yes, you are right
                  But you don't talk about which way you will handle the PT (spdif or HDMI)?
                  Generally there are some problems with PT with some AVR's at the moment but it is better with each new fw so I think they will be able to fix it completely during the next time...
                  XBMC have a problem with PT at HDMI (they will be also able to fix it)...
                  MX-Player:
                  Sometimes google could be a friend
                  => http://www.amazon.com/review/RIN3QSDGPIY81
                  RK3288 Devices
                  - Overview BOX (LINK !)
                    Please test improved SPMC Auto_Frame_Rate_Switcher for your HPH devices.
                    (Link removed, see new link from developer)
                    Unzip and install as addon from zip.
                    Go to Program addons to define the shortcut keys and enable the service. Restart SPMC afterwards.
                    Press your short-cut keys to change to 24/50/60hz or automatic.
                    Update: For universal RK3288 Frequency switcher use new one from developer here
                      seems to be working great bro switches to the rates i map. for some reason my screenshot dont show the movie playing lol
                      The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
                        And 24
                          am i that silly.... tried last word on my box or are you meaning the sentence you posted with full stop ?.... cant unzip it
                            Pass: Last word on back of your box.
                            Where do you get it from?
                            Is it the mod I mentioned at the other thread?
                            EDIT
                            mean this thread http://www.freaktab.com/showthread.p...376#post251376
                            RK3288 Devices
                              EDIT
                              Similar to that.
                              I worked with the developer to fix it for HPH RK3288.
                              The previous one posted at Beelink didn't work, but it's probably also updated today and will work with other RK3288 devices now, previously only worked on RK3188 devices.
                              Some people say this addon is also not needed in SPMC
                              This has similar effect:
                              Framerate-sync Settings
                              1. Go to SYSTEM -> Video.
                              2. Go to bottom Settings level, press 2 times to toggle to "Expert".
                              3. Go up to Playback -> Set "Adjust display refresh rate to match video" to "Always".
                              4. If it does not work, try to use remote control back key repeatedly to go back to XBMC/Kodi Home UI and go to the bottom "Power" button to EXIT properly. Then, launch XBMC/Kodi again.
                                ... it's probably also updated today and will work with other RK3288 devices now ...
                                That would be nice...
                                RK3288 Devices
