This ROM is:
Rooted
Debloated
English as default language
init.d support added
Busybox commands added
Multi-User support added without the need for Xposed Framework
Google Play Store fixes added
Reboot app by Petrus
Your choice of 4, 6, 8, 10 and 12gb user app space (select the parameter file you want to flash) The default is 6gb
Optional TWRP Recovery included in the RileyROM folder, thanks to Abdul_pt (flash TWRP after the first boot with stock recovery).
Thanks to Geekbuying.com for providing me this and many other Pipo tablets to develop.
The RK3288 firmware prevents me from auto installing TWRP Recovery, so you will need to do it manually. I recommend that you first flash stock recovery with the whole ROM. After first boot, you can then install TWRP Recovery by itself, by running the flash tool, and un-checking everything except recovery.img. Browse to the TWRP file in the RileyROM folder of the ROM kit by clicking on the box to the right of the recovery line in the flash tool. DO NOT ERASE IDB a second time...just "switch" to flash mode and flash the TWRP recovery image.
Download wifi version
Download 3G version
TWRP Recovery (Works on either ROM)
Enjoy!!!!
Please.....Don't forget to donate....this helps me continue further ROM development.
