NEW - MK808B-Plus - Finless ROM 1.1
Originally posted by prahjister View PostAndroid TV remote in the play store
Ah thanks, this one?
Is it any special ? or i can use any remote from various developers?Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Nice work, Bob
Bob.. Your version 1.1 works well. USB Ethernet works as stated. Having TWRP embedded is really nice. The readme gave some options that I found useful. I did a wipe of the unit then EXT the zip and it installed cleanly. The included 13.4 XBMC .apk works well and I have no issues. Not having a remote to power off and on, I reboot into recovery and leave it there until needed again. As close to Sleep as I can figure. I could not find a wakeme app.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by exander View PostDoes it support 1080p 60Hz only? Is it possible to set 50Hz or 25Hz?
Originally posted by burimek View Postnot realy whenn test with screen resize or xbmc/kodi display ist 720p. select 1080p or i same result 720p
Originally posted by ker View PostAs you can see, 720@60Hz and two cpus.
You can also check display settings with https://play.google.com/store/apps/d...dro.screensize
Originally posted by exander View Postseems that something is wrong with the latest Finless ROM... Guys from Russian forum said that stock ROM displays 1080p.
You can also check display settings with https://play.google.com/store/apps/d...dro.screensizePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1772 users online. 0 members and 1772 guests.
