NEW - MK808B-Plus - Finless ROM 1.1
IPTV streams stutter with USB Ethernet
When Streaming live HD TV (3Mb to 4 Mb) using WiFi works fine.
The same streams via USB Ethernet, the picture stutters and breaks up.
Tested 2 types of USB Ethernet dongles, Speedtest shows (on the cheaper one) max 6.5Mb and another USB dongle gives the full 30Mb, my connection max.
Any ideas ?
CheersLast edited by Johnoo; 16 January 2015, 13:46.
Originally posted by dmarkey View PostAnyone have any luck with CEC? It seems the hardware supports it, but I don't think the kernel module is acting correctly.
Also, I don't seem to be able to attach my powered external hard drive. (It has a built in usb hub which may be the problem).
Just wanted to say thank you for the rom.
The only working method for me was to use the amlogic tool and update 107k to 109k, and after install the finless rom.
Logitech bluetooth keyboard k480 works great
sixaxis controller worked too with ps3 joystick, il played with snes emulator but ppsspp is very slow with 3dgame.
popcorn time was a bit laggy sometimes but maybe it was just the the peers.
youtube in 720p is ok.
Is anyone else having issues with video stuttering on this device?
Videos are playing fine and smooth except for this annoying one-frame skipping/stuttering every second (clock precision). It appears as a frame rate sync issue but I already tried all different settings without success.
I haven't checked the mouse pointer thing as mentioned in other threads for RK devices but I wouldn't be surprised if this was the same issue.
Suggestions?
Originally posted by ker View PostWhat is smpc?
Enviado desde mi A0001 mediante Tapatalk
SPMC is an off shoot of xbmc/kodi made by Koying - just type spmc in to google, you will find plenty of info about it.
mk808b-plus one unit did not flash correctly
Originally posted by Finless View PostHere is my 1.1 ROM for the MK808B-Plus.
This is made from the latest 109K4 release that fixes USB dongles (kind of).
Everything is pretty much the same as my 1.0 ROM as far as what I did to it.
Note: If you are on 108K4 it has a messed up recovery thus you MUST use the recovery.img I provide in this ZIP package.
__________________________________________________ __________
The other I had troubles with. I used the usb flash and it boots only to TWRP. I try to reflash using TWRP but a reboot always returns to the twrp menu. I've tried other methods with recovery and such, and those fail too. I can never get past the boot loader.
Any suggestions? I'm at a loss as to what is going on. I can retry again and provide different details if needed. I thought trying to mount everything OR unmout everything might work - that does not.
again, any help is appreciated - or do I need to send this one back to geekbuying?
Originally posted by androider2 View PostI have two mk808b plus sticks. One of which I flashed with 109k4 and now have added finless by putting the zip on an sd card and updating through the mbox settings update.
again, any help is appreciated - or do I need to send this one back to geekbuying?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by androider2 View PostI have tried that. Seems to flash ok but will only boot to twrp.
a flash with TWRP seems to go OK. There is one error at the beginning about can't find /sys/ ... led sometiing
ok. seems the reset button is not working now.
I can get into what looks like the stock recover mode by following instruction one - but then I have an error with the signature of mk8080b finless 1.1 image.
I can flash from a usb stick plugged into the OTG port.
But when I reboot, I get an error that it can't locate sdcard . I'm wondering if something gets confused with the mounting of drives and the external sd at one point looks like sdcard and then at another it doesn't. I've seen this sort of thing with linux before.
Maybe I need to copy the finless image to the root of internal storage and try that?
There are currently 2774 users online. 0 members and 2774 guests.
