NEW - MK808B-Plus - Finless ROM 1.1
Anyone else got an issue using the onscreen keyboard when using TWRP - when trying to "format data" the onscreen keyboard pops up asking you to type YES to confirm the action, but simply speaking, it don't work, tried it on a monitor and TV at different resolutions and still no go, just wondering if it's something we are missing or if it's a common issue?
First, Finless thank you for another great ROM (you have made many of these android sticks really usable). I use es explorer over wifi with mx player to play videos off a shared folder. For some reason mx player keeps crashing after playing a video for a while, is anyone one else having this problem? Don't have a problem with Netflix so I don't feel that it's a wifi signal drop issue.
Excellent Rom, but I have WiFi problem
A few days ago I received MK808B-plus stick, I soon put Finless 1.1 Rom. What a relief after a lot of problems with stick with RK3188 chip. Everything works perfectly...
But I have a problem with WiFi. Working at full speed, half hour, hour, sometimes 2 hours. Then the speed drops to around 1Mbps. I have to turn off and turn on WiFi to come back normal speed of Internet.
Or put the my phone next to the stick and run Internet speed test. Then stick also come back to normal WiFi speed...?
Any idea how to fix it?
In build.prop I found these values for WiFi:
ro.wifi.channels=11
#wifi.interface=ra0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
#wifi.supplicant_scan_interval = 60
Do I have to change a value, that WiFi work constantly at full speed?
Sorry my bad English, Thanks,
First, thank you Finless for this ROM. Work well!
I want to use this stick on my projector (Acer K135), it native resolution is 1280*800 (not 1280*720). Any chance to manualy change the resolution of this stick ? I have try many thing (edit build.prop, modify system/bin/set_displaymode.sh ...) but nothing works !
I have same problem with WIFI, if connection is not very very good, connection is lost. I will try with original ROM to see if it hardware or software problem. Maybe TCP buffer modifications in init.rc is the problem.
If you use mele F10 deluxe remote (great hardware), by default some buttons are not well configured in android. See this video for the solution (tested and approved):
(Sorry for my English)
Yes, it is connected via a USB extension cable 80 cm away from the stick.
The problem is that the signal is excellent for a while, then drastically slow down.
I don't understand why it come back to normal when next to him works WiFi from one phone. Only from this phone, when I try it with others, the signal does not improve...???
Tried this rom with 2 sticks and in our casual observations WIFI does seem to be more unstable than running stock. It seems to us that download speeds when downloading large files can fluctuate wildly, this does not seem to happen when using either of the stock roms.
Like we said this is based on casual observations, rather than any kind of methodical testing.
Apart from this one issue, everything else about this ROM seems perfect.
@darko
try to turn off bluetooth and see how crowded is your wifi neighborhood (maybe switching channel might help)WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Originally posted by darko150 View PostThanks for the advice. Bluetooth is turned off, with WiFi Analyzer app I watched which channels are free ... I tried all the channels (1-11), the same problem ...Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Oh boy oh boy oh boy...what a piece of crap on an hardware even running this rom.
I remember now why I ended up selling a Tronsmart a few years back only a couple of weeks after purchase. I knew this pieces of junk are not stable and fully optimized but this time, I thought that it'd do fine for emulation only. For anything HD playback related, the Raspberry Pi is just far more superior thanks to the community support.
So I'm trying to set it up and it takes 10 tries to finally activate my Google account because the 2-Step verification wouldn't load the browser page where I have to put my security code. It took 10 tries for the Play Store to finally show anything more than a blank page. And now, it's been downloading RetroArch for the last half hour. It's reaching now 1 mo downloaded...of 49 mo, even with a 3 bars on my wifi icon.
Time to unplug it the ****er and sell it to a fool who won't know what a shitty hardware he's purchasing.
Back to set-up my Pi 2. THAT'S hardware with proper software support.
Originally posted by DannyBiker View PostOh boy oh boy oh boy...what a piece of crap on an hardware even running this rom.
There are currently 2883 users online. 0 members and 2883 guests.
