NEW - MK808B-Plus - Finless ROM 1.1
Hello, I am using a Logitech F310 which has an X-input mode that should work with anything that the 360 controller works with, but it seems that the xpad.ko file is not equipped to handle this. I was able to get it working with USB/BT joystick center, but it is not an ideal situation (unplugging the controllers and plugging them back in can be a hassle with that app).
Thanks!
Edit:
Works with the neo x8 file from http://freaktab.com/forum/tv-player-...ort-installer=
Edit2:
Some keys were improperly mapped (in games such as Soulcraft - triggers did not function properly), and it did not work with the Ouya apks. I noticed it was missing the key layout file for the Logitech F310 - Vendor_046d_Product_c21d.kl - Everything started working immediately after I placed it into the system/usr/keylayout folder. Just take away the .zip from this file.Attached FilesLast edited by masterfork; 09 April 2015, 00:34.
Originally posted by killeriq View PostGot this USB-LAN Adapter , but after connecting and speedtest.net i get like 0.3MB down/0.4MB up , so from weak WIFI signal i have even worse speed via cable
Where could be the issue? ive tried both USB ports. ThanksAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Got Ethernet working. After plugging in the Ethernet, you can't use the Android Settings but have to use the Other Settings to switch Ethernet. But now I am getting XBMC freezing. Audio plays but no video and it does not take any input (mouse/keyboard or the remote). Sounds very much like the issue described here https://www.reddit.com/r/xbmc/commen...dio_continues/. Wondering if there might be a conflict between the video and the Ethernet driver ? With Wifi everything is good (well as good as a spotty 808B Plus wifi would be). As soon as I switch to Ethernet, XBMC becomes unusable when playing videos. Has anyone else run into this ?
Originally posted by homediaddict View PostUnable to get Ethernet working
I am running two MK808B Plus with the Finless 1.1 ROM. Everything works great on wifi. I also got the USB to Ethernet adapter http://www.geekbuying.com/item/High-...et-314264.html
However whenever I navigate to Ethernet settings when the adapter is connected, the Settings crashes. It says "Settings has closed". Has anyone else got Ethernet running with the Tronsmart Ethernet adapter ? Is there a log file somewhere I can look at ?
Hi all
Kodi 15 alpha 1 released and I think it is a worthy must have upgrade, why
no need of root - which means you dont need to check if kodi has the right permissions
auto framerate and resolution change - eg. if film is 1080 running at 24 frames - the tv will automatically change to native film settings)- set this up in settings first
many audio settings have been fixed such as dolby, dts,aac
many many other enhancements
just a caution, I had to play around abit to get correct settings (this is not just plug and play)Last edited by thejackal; 03 May 2015, 23:30.
Hi, I just registered mainly to thank Finless Bob for this great work and to ask a couple of questions about some issues I'm having.
First question:
The WiFi performance on my MK808Bplus is terrible, even sitting next the router it can barely get 50% of my internet speed with speedtest.net. Its much worse where the TV is located, barely getting 1-2 Mbps so nothing works. ROKU works great from this location so its not a signal strength issue, the stick shows 4 bars and my $40 pre-Paid Android 4.4.2 phone saturates my internet connection with speedtest.net when placed where I had the MK808Bplus.
I had a Axis 88772 USB dongle and got the wired internet to work with static IP (I have a old wired connection where the TV is for my laptop back in the days pre-802.11b being "affordable"). But the main problem is the AT&T U-Verse app won't work over a wired connectionWith the stick sitting next to my router it does work when WiFi is enabled. So my question is, can the WiFi be "spoofed" so when WiFi is enabled it redirects to the USB Ethernet instead of using the lame WiFi on my device?
Second Question.
Concerning device "spoofing" can this be changed without a ROM re-build? You spoofed a Nexus 10 tablet, but it seems HBO, Showtime, Starz, etc. apps (all "free with our U-Verse plan) seem to block video output on a device with an HDMI output (everything works right up to the point of playing the selected video). They work fine on my Wife's Nook HD+ and my $40 cell phone. Googling on the problem, people seem to think its because Adobe Flash is missing, but I'm pretty sure my $40 4.4.2 Android phone also lacks Flash. I'd like to try to make it think its my LG Tribute $40 phone and see if that helps or not.
Edit:
How do I "like" this thread? Seems a real shame for it to have zero likes listed.
As a relative newbie to GoogleTV seems I've noticed another problem I seem to have lost SU. I had the same issue with stock, but not on Finless 1.0.
Several of these "cable TV apps" won't play video if they detect root on the device, so in SuperSU I disabled root with the checkbox in SU options, before installing them or running them.
In stock I let SuperSU update and assumed that is why I lost root. I didn't have the problem with Finless 1.0, presumably because I didn't let it update.
However, in Finless 1.1 I seem to have lost root without allowing the update, launching SuperSU to re-enable the checkbox gives this error toast:
"There is no SU binary installed and SuperSU can't install it. This is a problem!"
Anyone know how to re-root?
I've not had an issue enabling/disabling/enabling root on my 4.4.2 Android phone (not activated, I just use it for the cameras, and as a mini-tablet).
So far my Google Fu has been weak, seems I'm not alone in having the problem, but I've not found any solutions that work for it yet.
Originally posted by phinc View PostIf you are using a wireless keyboard/mouse, be sure to not connect it directly to the mk808b+ but use usb extension cord instead. The wireless dongles strongly interfer with the WIFI. I also suggest upgrading to Finless 1.1. It is the most optimized Android Rom out there. If you android is not a "must have" for you, i recommend kszaq's openELEC rom. Some report that WIFI is better that on Android.
I am on openELEC and i can stream FullHD over WIFI without problems and my router is in the next room behind a massive brick wall.
Hi First of all I would like to thank you on all of hard work it works great
Question is there any alternative / quick way for unmounting usb hard drives ?
As I tried stickmount it says its mounted or unmounted the hard drive when it actually hasn't
it just would be nice to have a quick alternative to unmount the drives rather than having to go into the android settings everytime
plus would be great to link an app to mount / unmount drives with kodi
Another question is there any recommended Wifi Adaptor for this read comments that were mixed regarding different ones
but I would like find out the most recommended one to use with mk808b plus
Hi could you explain what settings you had to adjust?
Tried the alpha 1 but x265 videos aren't working great for me also get random crashes during certain videos
I have no issues with a beta of spmc / kodi
but would be nice to have the official kodi alpha 1 working
Originally posted by cesarpt View PostTo install from Openelec do I need to install the recovery in the ZIP ?
There are currently 3780 users online. 0 members and 3780 guests.
