Inviato dal mio Nexus 5 utilizzando Tapatalk
NEW - MK808B-Plus - Finless ROM 1.1
Originally posted by vn800art View PostWasn't RPi2 equipped with M or S 805 from Amlogic? Other than that well said, Iso-Playback ! I also have really good speeds, only once had some slow speeds but it was on first run and Play Store and Google Framework were updating in the background!
Google tv remote app problem
To anyone using google tv remote app - I have a problem when using the app for browsing on stock or chrome browser. After a while the app disconnects and can't connect to 808b+ anymore, not until I turn off google remote in settings and turn it on again.
On the other hand if I use the app for controlling KODI it never disconnects, and works as it should. Does anyone have this problem and can it be fixed?
hid-multitouch driver?
Great ROM Finless! Is there anyway to add multitouch (as in a touchscreen monitor) support? It looks like the hid-multitouch driver isn't there in /sys/module/hid-multitouch. I am new to this, but I believe there is a generic multitouch driver that, if installed, would be there. I have tried the idc file someone else mentioned on here with no luck.
Originally posted by phinc View PostIf you connect the USB dongle for your Mele F10 directly to a USB connector on the stick, this could be the cause for your WIFI problems because these dongles can interfer with WIFI. Try to connect it via a USB extension cable and see if this helps.
New to this.
Hi, firstly thanks for the rom. Installed yesterday without issue. 2 questions.
1) how do I add an app to the home page, as a shortcut ?
2) wifi is ok, but plugging a norm sub Ethernet adaptor in, all I get is 'Ethernet connecting'. I did enter a static ip, so is it possible me adapter is not compatible ?
thanks
Originally posted by ibirkic View PostTo anyone using google tv remote app - I have a problem when using the app for browsing on stock or chrome browser. After a while the app disconnects and can't connect to 808b+ anymore, not until I turn off google remote in settings and turn it on again.
Related to this, I tried using xbmc home app to make kodi my launcher. It worked, but I then have to manually turn on 'Google Remote' and 'Remote' in the settings again.
I wonder if some of the googleTV framework is missing from the ROM and that causes problems sometimes?
Originally posted by skanavy View PostHow to change boot screen?
There are currently 2559 users online. 0 members and 2559 guests.
