Hi, my friends. I publish new mod-version U65GT_V2.0.2W_en_141231_mod Lepi.
Made on the basis of official firmware U65GT_V2.0_update_aatt_20141215.
ChangeLog:
1. Fully odex except modified applications.
2. ROOT by default Superuser app from Clockworkmod.
3. Remove all software in Chinese.
4. By default the English language during the first boot
5. Modified the boot.img:
a) support init.d through busybox;
b) Permissive mode by default;
c) checkbox is checked USB debugging on first boot, then you can disable.
6. Reduced the minimum brightness level and slightly lowered Auto Brightness.
7. Implemented a system application in the Font Chooser Settings \ Screen to change the font. Development hartec.
8. Boot logo and boot animation by author.
10. Implemented gps.conf file in my editorial for using GPS in Russia. If you do not fit, delete it or edit (\ system \ etc)
11. White Orange Theme is similar to MUIU.
13. Improved interface firmware for better readability of the text on the buttons and panels.
14. The firmware two launcher - Launcher 3 and ApexLauncher. Left to the user's choice.
15. On the USB connection now button instead of doing Tap on the picture.
16. When you start the white dialer immediately opens the numeric keypad to dial.
17. Changed power_profile in the hope of correct statistics of battery discharge.
18. Settings \ For developers introduced Engineering menu and Test menu.
19. Introduced animation notifications.
20. The pre-installed soft: TitaniumBackup, mobileuncle.toolbox, rootexplorer, Terminal, viperFX4.
Download:
md5: 2cfa8479ae8295732aba36e7c4ef2e8a
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
The first boot lasts a long time, you need to wait patiently and not to touch the display.
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
