U65GT_V2.0.2W_en_141231_mod Lepi
    Lepi thanx for your great work!
    1) I received 3 days ago my cube u65gt (16gb, v2.0_20141111). I would like to have a full tablet backup before I proceed and install Lepi's custom rom. So can anyone give me a link with 2.0_20141111 ROM so I can restore my tablet back to factory status if something goes wrong while playing with custom roms?
    2) @Lepi Is there any way to increase the app storage after I flash your rom (V2.0.2W_en_141231_mod Lepi)? If yes, please tell me how.
    thanx in advance!
      Hallo, i'm New in this forum.
      Lepi thanx for your great rom's!!!
      I have the 9X withe the serial number: U65GT32GB14249850241
      What happen if i flash the New Rom?
      Sorry for my Bad english!
      Greatings Form Austria
        Only for tablets with a serial number higher than B1426XXXXXXX!
        videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
        TWRP_2.8.1.0
        TWRP_2810_newTheme TWRP_2.8.5.0
        PayPal donate WMID410517421626
          thanx in advance!
          Not necessary, you can make a backup of your own rom, post a link to yours when it's made for future reference.
          There are rumors that Brian (900supersport) created a script for that, search is your friend.
          Cheers,
          J
            Cheers,
            J
            Brian's rom includes EBR files for 4GB and 6GB app storage. I am wondering if I can flash these EBR files only after I flash Lepi's rom.
              Thanks Lepi for putting Viper4 android in !
              Only one question, any hopes of cube/mtk giving us a lollipop firmware?
                After testing this room i think 1.8.5 is smoother imo , rolled back to that and defo see the improvement in tablet.
                  yes you can, but you need to backup your pictures before.
                  I flashed 4Gb EBR1 & 2 without problems (apart losing taken pictures)
                    Keyboard via cable and via bluetooth problem?
                    Hi Lepi,
                    Hi every one!
                    I`m new here and my english isn`t the best. I have flashed today the new software ( my tablet number:
                    143589..... ) and I have a keyboard problem with external keyboard either via cable and via bluetooth.
                    Both keyboards some letters do not work or false. Has anyone had similar experience? Is a patch in sight?
                    would a wipe-factory reset and flash repeatedly help, I flashed it via CWR without wipe-factory reset.
                    regards
                    sieg
                      Where can I download latest TWRP for cube u26gt?
                      edit: I found it! Link is in Lepi's signature. How can I install it? Do I need root before I install it?
                      Thank you
                        Yeah root and flash it via recovery
                          thank you.
                          Do I need to rename the file into "update.zip" or something? Or I just put it in the internal memory and leave it as it is?
                          I was hoping to root tablet using twrp. Now you tell me that I need to root first...
                            if you want to install TWRP recovery only you just need to extract the recovery.img and flash it via SP_flashtool, no root is needed to do this.
                              thank you. You have been so helpful.
                              Do I also need the scatter file for this? If yes, can I use the scatter file from Brian's (1.8) rom? Is this safe considering the fact that my tablet came with firmware v2.0_20141111?
                                The answer for all your questions is YES!
                                Scatter file for 1.8 is ok for 2.0 too.
                                If you flash TWRP recovery ONLY it is not necessary to made any backup, you will not lose any data.
